Page 11 of 76 FirstFirst ... 9101112132161 ... LastLast
Results 101 to 110 of 753
Thread: DIY phonostage.
  1. #101
    I'm Simon.
    Andy I chose the silver AudioNote sockets, they are an easier fit and take repeated solder/desolering better than the Eichmann's.
  2. #102
    No worries, I can see your point with the eichmanns they are a bit shit when it comes to repeated solders, I've made a few leads up In the past and had the same problem.
    PRE
  3. #103
    O dear I have just ordered 4 Eichmann bullets and sockets
    Alan
  4. #104
    Alan,
    Don't worry eichmann are very good. You should have no problems with the femals RCAs but the male RCAs can be a little fragile if used more than once. What do you plump for Cu or Ag?
    PRE
  5. #105
    Alan,
    4 Silver bullets on the phono plugs
    and the sockets are copper gold plated
    http://www.ebay.co.uk/itm/1308119553...84.m1439.l2649
    I am also contemplating Neutric XLR?? any thoughts
    for hook up cable I have a 5m length of 8 core Van Damme blue tour grade where each core has 2 upofc wire which are screened and jacketed so I am going to strip out lengths of that each pair of internal phonos
    http://www.van-damme.com/3.html
    The power cables are just good quality silver plated copper with Teflon sheath all twisted into a 7 core lead with a copper screen and jacket.
    Alan
  6. #106
    You would have to ask Simon about xlr's. Now with regards your cabling I think Simon used some monster thick belkin stuff again you need to ask him what spec he used.
    PRE
  7. #107
    I'm Simon.
    It's just the Eichmann RCA plugs that i find a little less than durable. Knowing Andrew he'll probably want to tinker about with different internal signal wires in his new phono so I've built it with a socket choice that doesn't mind a bit of thermal abuse. better safe than sorry.
  8. #108
    Me, tinker with hifi kit. Nope I'll prolly leave this kit well alone!
    PRE
  9. #109
    I'm Deleted.
    Quote Originally Posted by 337alant View Post
    Do you mean for signal out? If so, I see no reason why not.
    Account Deleted
  10. #110
    Yes I mean for all signal connections in and out (but unbalenced), I just think they appear to be a better connection than phono
    If I do it it would be to the end of the arm leads, sockets in and out of the phono stage and a lead to the pre amp so would need 2 extra sockets in the pre amp as well
    Alan
