hi all, id like to try a glass core optical cable, where should i be looking to get one? mark grant is always sold out and the cable talk 3 i found was too long, i just need a 1meter length, thanks jim
Have you looked on CPC's website? They have some very fancy looking opticals for far lower prices than QED and Chord Co charge for similar looking things.. Not sure if they're glass cored though.
hi david, ill have a look, i have a cheap fibre optic at the moment , which is ok, but keep hearing good things about glass ones , jim
These people sell All glass cables. I use one of these my self.
http://stores.ebay.com/Unique-Produc...=p4634.c0.m322
Here is your size.
http://www.ebay.com/itm/3-3-ft-GLASS...item5ae44888e1
Jeff :UBERTHREADKILLER
DaveK.
My System:
glass is a bit better than plastic , i was a cable maker for AEI (gec cable division) (marconni) through the 70s/80s/90s, if you fit and play , they found better transfer (slightly) till you , plugged/unplugged a few times , then the glass cable tended to splinter/fracture at the ends , plastic did not suffer like this (thats why you can put up strip down your fibre optic christmas tree without fail every year) so buy glass enjoy , just keep it plugged in
getting older and now getting wiser
thanks for your replies, i think ill try and get one of those from the states, happy new year !! jim
well i cant get the one from ebay usa,found the same one on amazon usa and no luck there either, i wonder why?
managed to get a 'sonicwave' glass fibre optical from amazon.com, £31 shipped fom usa to blighty, got to be worth a punt
