Hi and thanks for reading this post.
Do you think it would be a good idea to replace the usual aluminium electrolytic capacitors on a Zero dac digital to analogue convertor board for the better specs of a solid state (polymer) type capacitor.
I have 4 aluminium electrolytic's around the dac chip (47uf 35v) which are swollen and leaking, and 4x 10uf 63v output coupling caps in the analog section, so 8 caps to replace in all, do you think a like for like replacement of the stock aluminium electrolytics for solid state polymer type caps would be okay in this situation.
I have done a google search and people have performed this on pc motherboards but there is not much on other types of equipment.
Many thanks in advance. John.
