Just in case you're still around and haven't got any further with getting access to your vortexbox, this might be useful.
http://www.vortexbox.co.uk/index.aspx?pageid=437990
Simon
MINI DSP SHD; Longdog 300b; Reiver Fenwicks
Twitter @siashmore
I'm Andy.
Thanks for the link.
I have now more or less got it up and running OK now?
The problem with the devices on the Network page defaulting to 'Windows Media Player' instead of the relevant device webGUI looks to be because the Vista home premium software does not support 'Samba'?
But apart from that everything else seems to be running OK.
However, I wish there was an android tablet equivalent to iPEN as the Logitech webGUI and their android app are not great and as far as I can make out none of the 'pay' for versions are not much better?
Squeeze Commander is an excellent app and betters the Logitech one in every way possible
http://www.squeezecommander.com/
Glad it's mostly sorted.
I upgraded to Win7 after suffering Vista for far too long. It's a worthwhile upgrade.
+1 for Squeeze Commander.
Simon
Simon
Twitter @siashmore
I'm Andy.
I'm Andy.
Try posting a new thread with the question in the section in Abstract Chat. Our resident IT geeks would pick it up far quicker and post the various solutions that would help you out.
Website: http://www.homehifi.co.uk
Website: http://www.beresford.me
Website: http://www.homehifi.asia
Cheers Stan...
You should have no trouble upgrading from Vista to Win 7, in fact your computer will thank you for it!
There should be a simple upgrade option on the installation disk, one thing to note Win 7 comes in 32bit or 64bit flavours, so you might want to check your CPUs capabilities...i.e. is it 64bit compatible?
I'd suggest you go with 32bit, you'll have less hardware driver issues.
Your files should be safe, but if they're important I'd be storing them on an external HD anyway, a computer's C: drive is not the safest place IMHO
I shall geek off...
P.S. This link may be of some use...
http://windows.microsoft.com/upgrade-windows-vista
Cheers, Will
I'm Andy.
