Looking for a cheap brush to scrub your LPs prior to vacuuming off the cleaning solution?
I picked a couple of these up at ASDA for around £5.00 for the pair.
Chris
Common sense isn't anymore!
Looks interesting, how effective are they and have you compared them to anything else?
Vinyl rig 1 - NAS Spacedeck / FR64s / Lab 12 Melto / Denon SUT / Ortofon GM SPU. Vinyl rig 2 Mono Set Up - Lenco GL75 c/w Jelco 750D / AT33 Mono / EAR 834P Modded. Amplifiers - Audio Note Empress Silver / Hattor Passive Pre. Digital - Fanless Mini PC / Lampizator TRP / Linear PSU / Hummingboard Network audio adaptor. Speakers - Horns.pl Mummy's. Cables are Audio Note / Albedo / Furutech Speaker wire. Power conditioner is a Gigawatt PC2 EVO
I'm Nobody.
Flock paint pads, you can get small ones around 4'' square with handle ontop..
I still swear by the KAB 'Discsweep' brush - goat hair and 'Thunderon' anti-static nylon mix with nice short, stiff bristles and an easy to grip handle. About 12quid or so including delivery from the US.
Keith
Analogue: Lenco L75 with 'PTP5' top plate in heavy birch ply plinth/re-wired Rega RB300/SAE 1000e HOMC Cartridge/Trans-Fi Reso-Mat/Moth RCM
Files: Voyage MPD/Custom PC/Supra USB/Beresford ASYNCH-1/Beresford TOSlink cable
CDP: Inca Katana SE
DAC: Beresford Caiman MkII (LiPo Battery powered)
Pre-Amp: Croft Micro 25 Power-Amp: Croft Series 7
Speakers: DIY Frugel-Horn Mk3 ('FH3') + REL Strata subwoofer
Headphones: Beyer Dynamics DT990 Pro (250 ohm)/Schiit Asgard Headphone Amp
Cables - Interconnects: Mark Grant G1000HD Speaker Cables: Van Damme Blue
Mains: Belkin PF30/Mark Grant DSP2.5 & DSP1.0 Rack: Target
Office System: HP Win8 Laptop/JRiver/MF V-Link2/Beresford Bushmaster MkII/Topping TP20 Mk2/Mission 771e
Bedroom System: Raspberry Pi/Raspbrian + MPD/HiFiBerry DAC/Topping TP20 Mk2/Mission 760i or DIY Hybrid Valve-MOSFET Headphone amp + Sennheiser HD595
Gallery
Mmmm..... I prefer something with stiff (reasonably hard) bristles, which you can apply reasonable pressure to, and work deep into the grooves to dislodge any deep-down crud. Those found on a shaving brush are too soft, and also tend to shed after a while and land on the record surface.
For the most effective cleaning, I've yet to find anything better than the brush that came with my VPI 16.5 RCM:
http://www.lpgear.com/product/VPIE3010.html
You want nice STIFF bristles, in order to do the best job!
I'm Nobody.
Those paint pads are reasonably hard Marco..
I was going to ask you that, dude, as I couldn't tell from the pics. In that case, cool!
The bristles on the VPI brush are made from a kind of nylon/acrylic material, and it really dislodges the most deeply-ingrained crud. Then again, I spend a good 10 mins, or sometimes more, cleaning a record, until it shines like a mirror!
The result is near-silence, in terms of noise, during playback, and a crystal clear sound....
I'm Nobody.
I suppose with em being low level you have to be carefull not to catch your LP with the corner..
I'm stu.
I use the brush that comes with the parastat;
Looks a bit soft, Stu?
