iPhone 3GS 16GB
For sale is my iPhone 3GS, in excellent general condition. It has a screen protector fitted so the screen is as mint as can be. It does have a very slight crack at the bottom of the rear case but this is barely noticeable - not at all if you use a case like I do. Case will be included if you like? It's missing the volume switch but this doesn't stop being able to control the volume, this never bothered me but I'm sure if you want a replacement you could get one easy enough for little money.
Comes in original box which is also in excellent condition, with plug and USB cable (cable is tatty but works perfectly).
I used it on Orange, not sure if it's unlocked but will try and borrow a Sim card to find out.
£100 delivered.
- You may not post replies
- You may not edit your posts
Forum Rules
