I've always wanted one of these, and they are getting difficult to find, so i thought let the sellers come to me!
I'm andrew.
Mike
I'm andrew.
Mike
also this one
http://cgi.ebay.co.uk/ws/eBayISAPI.d...d=413547075847
Mike
I'm andrew.
I'm andrew.
I'm scott.
I'm andrew.
I'm scott.
worth a try andrew , can send you one of these to try
fon lo thingee is basically a very high end bluecircle phono stage
in a plastic drain pipe to reduce the cost , but keep the performance
have standard , biggie & sp power packs to suit with MM/MC inputs
http://www.6moons.com/audioreviews/bluecircle4/flt.html
http://positive-feedback.com/Issue48/blue_circle.htm
http://www.goodsound.com/equipment/b...lo_thingee.htm
