A second ringing endorsement bodes well then.
There's such a lot of disinformation out there regarding tubes, it can turn the head of the unwary. For the record, I consulted Joe's Tube Lore
which is where the slur re. JJ's not matching up to Tesla standards originated. The tube jungle can be a daunting place for the inexperienced I have to say.
So... we have on our list of options an ECC88/62JD/6N1p (and -EV) morphing into E88CC/CV2492/6922, E188CC/7308, ECC88CCa, not to mention the 6N23p (and -EV)
I realise you have to occasionally kiss a few frogs before finding your ideal partner but swimming with the toads can be a time-consuming business. I suppose the moral of the story is not to succumb to the irresistable itch to grab at the nobbly allsorts being routinely proffered on eBay and to, well, listen to unbiased advice.
Thanks chaps.
I don't know about the valve you want but I'm using JJ ecc82's in my pre. I swapped them for some old yellow label Mullards but swapped them back as the Mullards were noisier.
They're a good quality valve.
Steve
Thorens TD550, Ortofon 12", Ortofon Jubilee or Koetsu Black; Rothwell MCL SUT, VTL 2.5 pre, XTC POW 1 power; Naim CD5x; KEF Reference 3.2's; Van den Hul interconnects and speaker cables.
I'm Karl.
Any chance that we could examine the schematic of the Audion Sterling?
This might help narrowing down selections.
Most of the time I use russian 6N1P instead of 6DJ8 and E88CC.
Avirtual trip to the Tube Amp Doctor.de might solve your problems...
Short answer to that Karl is no, unfortunately I have no plans to open up the Sterling. But, bearing in mind that 6N1P's can be had so cheaply, I may well have a go - presumably no damage to the amp will occur due to the slight variation in plate voltage? Would you happen to know the answer to that? How do you find the sound of them?
God is dead, Marx is dead - and I'm not feeling that great Myself...
I'm Karl.
The higher allowed plate voltage is a big plus, if the circuit is less than ideal, you won't damage the tube or anything else.
I've compared them to RCA 6DJ8 cleartop en Telefunken and Siemens NOS E88CC, not much difference to my ears (at least not in the used circuit, grounded cathode followed by split load phase splitter driving a couple of EL84's).
The 6DJ8 sounded sweetest, Siemens a little "harder", Telefunken was very neutral and musical. I'd say the 6N1P-EV I used sounded like the Telefunkens.
When driven harder, the 6N1P-EV seems to distort less.
But it all boils down to the circuit they are used in.
Oh, and one tip, if you buy from our russian friend, take 10 tubes or so, very often, 8 tubes are perfect, 2 are out of spec.
If you want tubes "on spec", the tube amp doctor is the place to be...
Technics SL-1200 Mk2 recapped / MN bearing / Funk Firm Platter / Denon 103R / Lundahl LL1933
Thorens TD 126 MkIII / SME Series III / Ortofon SME 30H // AT-OC9ML/II / Lundahl LL1681
Thorens TD 160 / TP16 / Stanton 681SE
Well in the past I've had some success with Russian valves - courtesy of info via the Lampizator website - including x2 6N6P's as drivers in a 300B integrated as well as using one as a replacement for a 6H30 in a tube buffered player where the relative laidbackness of the variant works wonderfully well in tandem with a frisky Bantam Gold amp. Also, I have tried a pair of 6N23P's in the Sterling which were a huge improvement over the JAN Philips 6922 it came with but which broke up over a relatively short time, matter of months.
I've never tried the 6N23P-EV but I probably will.
Anyway, interesting about the 6N1P-EV, I think I'll give those a shot as well. Thoroughly agree about the need to exercise particular caution when eBaying these Russian tubes which I suppose is the trade-off for their affordability. So off to the tube amp doctor for a wee butcher's...
I'm Karl.
Have a look here:
6n23p
It seems the measured 6N23P is not an exact substitute for ECC88.
In circuits designed with GlassWare TubeCAD for the ECC88, an actual 6N1P measures the same...
