Look this nice transformers which I make.
Interstage. Ouptput. Power...
Simple FeSe core (military factory made)
W-core, toroid ,U-core
Amprpheus toroid core ( with ear-gapp )
Toroid have m=90000,60000,120000
hi nafanja,
nice...
where are you based.
regards,anthony...
It's nice to have someone from that way wanting to talk about transformers annd other on-topic stuff rather than advertise porn.
If they are good and the price is right...
I am from Ukraine.
My grand mother and fother from Russia.
But more time i am in Ukraine.
the vintage core from USSR. Ukraine was be USSR.
I am between Russia and west Europe.
The price I will show you at the nearest time.
But all constructive nuanses we may talk.
I think that the price you like.
In a future I will show the work under the transformer.
I make the transformer for ltra-High-End eqipment.
I have a diofferebt line - from 40 USD for transformer to...
Like the weight and dimentions...
Your picture is grate, and your Marshall(s)...)))
Tell me plaese do you desighn the chasees?
I have here Ibility for making aqipment.
Look the factiory for methal work and partner for disighn.
Interesting to know about you...
To look your answer and threeds I am glad too.
This is a waunded chokes...
After that they wil be paynted.
It's for curent up to 0.8 Amper...
20-40 Henry...
I like this dimentions for tube amps...
This transformers exelent for the wound there SE abd PP variants...
This tubes like GM70, 6S33s, 6S41S, 6P3S, G807,GU50, 6P45S, 6S19S and other tubes..
KT88,EL34 and many other parameters...
exelent core transformers...
I like that they have a good mass...
I am olso have a factory which make the amorpheus cores with m=90000 or 120000.Fe or Co...
This variant of amorpheus Fe I am use at the buffer for the DAC.
TDA1541. this is a very interestinf DAC.
This transfrmer have good parameters and small size.
0Hez up to 1 Mhz - it's what I have in the measuring...
Tis transformer exelent for doff swecondaru for PP tube amp..
Some of the cores i am use like interestage for 6n1p,ecc88,6s45p tubes and many other...
The picture here
Here is the little babies...
The factory 1500 Va transformer I am use loading for 25-75 VA...
At the regenerator for power naer 300 VA - I am use for 1500 VA transformer core...
the sounds is exelent, and it'sd may here at the equipment not just good 50-60 Herz...
Low THD... And thing mid...
