Not sure what was meant by a high impedance valve, the EL34 has a set of characteristics that will be broadly the same from manufacture to the next so the plate resistance and other characteristics will more or less be consistent as the valve is an "EL34"... The construction may vary but valve from one manufacturer should work in the same cct as one from another...
