fooking hell Joe you were correct about them looking like monoblocks. Well done incidently, I'll keep you updated with my secret project
Many thanks chaps... Just the finishing off to do now!
Tannoyista.com - Audio Equipment Reviews
Hi Joe
Are you still using the little 4-pin Tannoy plugs, or hardwiring the crossovers directky to the LF and HF coil terminals? Also, did you settle on any particular autoformer tap for best HF balance?
I'm pretty much decided that I'm going to restore my Lancasters and will probably get Nick to do the crossovers, since he has my Sowter autoformers and you have been a good guinea pig!
I'm Eugene.
Nice job, Joe!
Any idea on how we can get pics of joes reworked cross overs, now im in the market for some making I'd like to see what he's used.
Those wanting to have a go at DIY versions minus the crossovers need to be careful here! I guess you've used the autoformers Joe, so no circuit changes are needed.
If not using the autoformer and using a fixed value inductor, you will not have the correct values if you use the yellow tapping values. Yellow tap may be what Tannoy show in the crossovers as flat, but it is not the electrically flat tapping. That is the Green tap not the yellow.
Bear in mind when you choose an inductor value if it is a fixed inductor value, it should have the same inductance as the green tap which is about 2.9mH and not the 4mH of the Yellow tap.
Furthermore, the green is connected back to the orange tap which makes the reflected impedance ratio 2.0, so for a fixed inductor value, the correct value for the shunt resistor is not 50 Ohms, its 25 Ohms. 50 ohms at this point will put too much energy into the HF circuit at the expense of bass. Any less than 25 Ohms and you will stress your amp but not change bass/improve response.
With the autoformer in circuit you do not have to worry about these things but many DIY/Forum diagrams I've seen for DIY fixed value crossovers have been wrong because of these points. I'm happy to confirm and supply the correct values if anyone else is having a go at DIY fixed value crossovers minus the autoformers (don't forget that these act as step-up/down transformers as well as a variable inductor).
