No wonder I was a bit ambivalent about it - s'cuse the pics..
Here's the date stamp if anyone can date it..
Nice one, Dave. I thought it would be a Mullard. I'm not up on date codes, so not sure exactly how old it is. I would guess 1960s vintage, as it has the older Mullard 'shield' logo. In the 1970s the logo was changed to a 'diamond' shaped one.
Thing is, the one you've just bought is a military spec version, and brand new old stock, so given how much use your current one's had, I doubt you'll not hear the difference when popping in the new one!
I look forward to it. that means all the supply valves are now updated (other two are 60's Mullards too).
I'm jan.
Hi
I also waiting for some 85a2 valve, to try them in my Croft
jan
The valve arrived today, beautifully packed in an outsize box with "hundreds and thousands" poly chips surrounding it.
Now, I cannot in all honesty say that one valve sounds better than t'other, since the one which was removed has over twenty years varied use behind it and a previous owner from new until three or four years ago, but I can say that I'm glad I did
For whatever reason, the sound of the preamp's output now more closely than ever mirrors its input, the slight fuzziness that had crept up on it in recent times very much reduced, if not eliminated, and the rendition of reverb and atmosphere is enhanced if anything (this into the old HH VX300 amp too). The LS5/9's sound as if they've had a tweeter transplant
Thanks for the suggestion Marco. I don't at all mind updates of this magnitude for a tenner's worth of outlay........
Nice one, Dave. I thought you'd be able to hear a difference... All these 'little things' matter because, cumulatively, they all add up!
I have several of these spare as my S4s uses 3 - 1 on the input and 2 on the output circuit.
I remember discussing these tubes with Glenn a while ago - he uses Mullards and all my spares are Mullards - BUT, some examples don't "glow" at the required voltage for the circuit to be stable so I made sure all the ones I use (and the spares) were pre-tested by Glenn to ensure they were up to spec.
Steve
Always a little further
These valves really are "valvey" looking in Mullard form. The CV one I've just fitted is silvered and the only way you know it's working is a faint glow at the tip - the silvered bit hides the gubbins inside.
As I said before, I have no idea of the lifespan of these things or how they behave under different loading conditions, but thanks again for the tip - worth every penny since I love this old preamp and would only change it for the two box Croft RS in all honesty.
I'm Richard.
Thanks both - just ordered the last one for my Micro II after checking it last night and finding a no-name item in there.
Richard
Richard
As per my post above not all these are created equally - regardless of the manufacturer they need to "glow" at a specific voltage in order to allow the relevant circuit to perform to spec and some just dont. You might want to D/W Glenn and perhaps get some direct from him that he has tested.
Steve
