Hi Duncan, thanks for the info but I have already seen these circuits on the Italian site, the M-408 is a completely different ball game, and quite different to the M-1008 unfortunately, but I appreciate your help and time. I have been working on the duff M-408 for the best part of the day and I believe that I have now found the problem, there are 2x 0.22 ohm 4 Watt Welwyn resistors gone open circuit, one is fried, both output transistors TIP146 and TIP147 are reading around 1 ohm between collector and emmiter junction and the 2SC546 that senses the temperature of the output devices was totally cooked, all this adds up to a very sad amp, I have most of the parts so a rebuild will be underway when I get the Welwyn resistors from Farnell, I think I will eventually remove the protection circuit as a good colleague of mine has suggested that it does not really need it provided I don't try to run it into a couple of ohm load, so the day draws near for the final push to hear these birds sing again.
Thanks again Duncan for your offer of help, truly appreciated
Paul
