Its sorted now
You need to be careful when locating the LP it can get caught on the shaft below the threaded section
So located properly and tightened down a bit firmer it now works
I'm Allen.
Its sorted now
This happens with the Moth RCM as well.
After you've used your RCM you will get used to how tight the screw should be. Using a plastic washer may help.
The Moth RCM spins clockwise and anti-clockwise and when vacuuming I spin one revolution each way.
I'm John.
I found the nokki clamp will leave a small circle on the label more noticable on light colour labels, the plastic washer I use cures that.
I've been considering buying an RCM, would you say the Okki Nokki does a good job?,
There are so many and vary so much in price, am I right in assuming that after the cleaning fluid has been allowed to do it's job, they all remove the fluid by means of a suction tube with a slot in it and a fibre protection strip?
Moth, Okki Nokki, Nitty Gritty, VPI................ any suggestions please
regards Al
My system,
Cartridges Lyra Delos, Audio Technica AT33EVmc, AT 24 mm
Turntable Thorens TD 124 Mk2, in a Jim Campbel plinth,Audio Technica 1503 Mk3 arm
CD player Technics SL-PG490
Cassette deck Yamaha KX 530
Moving Coil Amp Albarry MCA 11
Pre-amplifier Albarry AP 11 (battery powered)
Power amps Albarry M1108 Mono-blocs
Speakers Allison 3 Corner units, Allison 6 stand mounted cubes
Interconnects AVT Matrix 6 and OFC short ones
Mains distribution Music Works Recoil 6 gang and mains leads
Tables MusicWorks ReVo acrylic stand, Quadraspire Acrylic shelves (cryo'd legs) acrylic Response Mini under mains block.
Speaker cable Chord Rumour (Cryo'd)
RCM Okki Nokki
https://www.facebook.com/groups/1586...homepage_panel
I'm stu.
I use a different brush than the spreader provided as it's a bit rubbish.
Okki does a great job.
301/Puresound 2A3/quite large Grf cab horny ones.Eminence/Coral/Le cleach
I'm Allen.
What brush do you use ?I use a different brush
I'm stu.
The brush that is in the middle of a parastat cleaner.
I was initially disappointed with the results I was getting using my recently purchased Okki Nokki, but I found that the brush supplied was a bit lacking (not getting deep enough into the groove to dislodge any dirt) and changed it out for one of the Mobile Fidelity brushes.
I'm now very pleased with the results I'm getting, and the Okki Nokki sucks pretty much all of the fluid and dirt from the discs surface.
Chris
Common sense isn't anymore!
I'm Allen.
