Yes! It arrived a few weeks ago and fit perfectly! I was a bit worried i'd have to realign the arm in order to be able to extract/insert the din connector. As Michell owners know, there is not an abundance of space under the tone arm plate.
But it went fine and only takes a couple of minutes to change the cable.
The initial impression was very Nordost-ish... Plenty of space, depth, width and clarity. A little skinny though. But after a couple of days the cable had "settled down" in it's new habitat and the sound gained a lot of weight and definition in the lower registers!
Now, a couple of weeks later i am very pleased with the new cable! The analog front end gained a lot of resolution and a "step in soundscape" along with greatly increased definition and perceived depth in the bass!
Not cheap but a similar increase in quality as a new cart, a better RIAA etc.
/Mike
