1 into 2?
I have an Avondale Grad1 pre which only has one line out via RCA connections. I use a Mogami interconnect with a pair of no-name generic connectors each end. I switch between my S100 and headphone amp by unplugging from one and plugging into the other (both switched off). This is tedious and I am concerned that I could, over time, do excessive wear to connectors/terminals.
I had thought of having a Y-cable made up so S100 and headphone amp are always connected with one always switched off while the other is in use. Will this noticably degrade the sq? Are there any other ways of doing this other than replacing the pre? Would I be better off having two sets of interconnect always connected at the S100 or Head amp and swap over at the pre each time which would be easier as it is at the top of the rack. Danger here is ensuring the unit not in use is always switched off.
I have looked at Mark Grant G1500 and 2000 and the Yannis 223.5. Any views on how these two compare as regards presentation and would either be a better fit with my system. I am using ATC SCM40s with NAC A5 at present and I like an open clear but smooth sound. Will probably be looking to change speaker cable also as I need longer lengths so a recommendation for suitable replacements here would also be gratefully received. I like the NAC A5 and would use that again. When I tried Chord Epic I felt there was not a huge improvement, if any, especially considering the price.
Any advice most appreciated.
Best regards,
Keith.
Garrard 401, Groovemaster 2, Arche headshell, Miyajima Shilabe, Paradise Phono amp,
Aqua La Voce dac
Salas DCB1
Najda active crossover and DSP.
Crown XLi 1500 x 2 bridged, Neurochrome Mod 86 monos, Guy Sergeant Hiraga Le Monstre,
DIY open baffle with 18" Fane Colossus XB, Beyma 12p80ND and Beyma TPL150H with BK XLS 400 sub.
