I'm stu.
301/Puresound 2A3/quite large Grf cab horny ones.Eminence/Coral/Le cleach
I'm Nobody.
Me so horny- Impulse H6 Horny
I'm Nobody.
That is it sat on our dinner table..Quiet nice quality, im fussy swine aswell.. Seems to work great, i put a little pad on it as not to damage the styli tip..if you switch it on after you placed the pad it defaults to 0.0g. switching on then adding the pad will obviously clock weight up.
