Results 1 to 4 of 4
Thread: Foundation / base for a system ?
    I'm Allen.
    Default Foundation / base for a system ?
    Hello
    During my short time as a forum member I have read with interest lots of posts re
    Plinths
    Stands
    Spikes
    Gel pads
    ceramic feet
    to name a few
    In 2006 I had to empty the ground floor of my house and replace all the floors and joists due to rot
    not a pleasant job but someone has to do it and it , this is a photo of the hallway to give you an idea of the chaos
    I replaced the joists with treated 4" x 2" and 18mm floor boards
    Is this good enough to call a foundation ? Well it now has to be because I am not pulling it all up again
    Next , for my speakers I have a pair of Atacama stands At the moment not filled with anything , and my speaker are just sitting flat face to flat face , No pads , spikes , feet
    How would you proceed from here
    Also some advice , my speakers are rear ported , is there a recommended distance the speakers should be from the wall ?
    And lastly is there a recommended triangle formula for
    distance between speakers for a set distance for the listening seating position , If you see what I mean ?
    Cheers all
    I'm fuckoff.
    I replaced my spikes entirely with RDC spikes, cups and foam inserts, the difference it made was huge, all of a sudden my speakers had bass and the treble end of things was much more detailed and delicate, one of the best upgrapdes I ever made.
    See my other thread for Atacama based stand filling experiments; I'll update as asoon as I've tried it out. The concensus is sands (kiln dried, fine as you can get it) a great place to start
    I'm Allen.
    Hi Martin
    When you say you replaced your spiks , were these the ones on the base of the stands / carpet or the one's at the top of the stands between the stand and the speaker , are they these http://www.audiooasis.co.uk/en/prodi...LE-ACC-IS-RDC1
    if not do you have a link to the ones you have used please ?
    Thanks
    I'm fuckoff.
    Yeah, I replaced the spikes at the bottom of the stands with:
    RDC 1 cones (6mm thread)
    RDC cone cups
    RDC combi bases
    Which provided a tremendous upgrade to the way my speakers sound. I'm sure that even if you just used the new spikes it would make a big difference.
    Also, I recently removed the gel pads that came with my stands (the Atacam ones) and this was a not insignificant jump in detail retreival for my speakers. Alt hough I can't universally vouch for this bit as it depends on your gear but you should definitely try both with and without (I had them on for about 10 months before trying )
    I was worried about the lack of grip for my speakers and so used some of my mates Plastidip spray (in black). A few coats of this means my speakers aren't stuck down but they ain't going anywhere if knocked either, really is great and useful stuff!
    Hope this helps.
