Results 21 to 30 of 46
Thread: Lights out for incandescent bulbs
  1. #21
    Quote Originally Posted by Thing Fish View Post
    I have enough 100w bulbs stockpiled to see me through this life...
    Those energy abominations things are shite...!!! and I refuse to use them.
    The light bulb Nazi's are watching and know who you are!
    Jeff :UBERTHREADKILLER
  2. #22
    Quote Originally Posted by prestonchipfryer View Post
    Well done, I've got enough too!
    Absolutely!! Forced on us by cretinous authority.
    You are surely not suggesting that our glorious leaders would exercise questionable judgement?
  3. #23
    synsei Guest
    But guys, the use of energy saving lightbulbs will help save the planet and make you feel all warm and fluffy inside...
  4. #24
    I'm going with arch lighting myself{[ ("screw the planet")]}!!!!
  5. #25
    Quote Originally Posted by goraman View Post
    You could always light your home up with a pair of the old Magnat plasma arc speakers with the lurid glowing globe tweeters and all that ozone generated must be as bracing as sea air!
  6. #26
    I'm John.
    Light up the sky with one of these little beauties. And also decimate the light police.
    http://www.wired.co.uk/news/archive/...ing-bolt-laser
  7. #27
    We never got tired of the lightning bolts zapping our simulated targets," admitted George Fischer, a physicist leading the project at the Picatinny Arsenal research lab in New Jersey.
    I'll bet they didn't.
  8. #28
    I'm Alex.
    I have a lot of gu10 type downright in the kitchen, and have installed 4w multi led replacements in brilliant white. They dim ok if you have enough on the circuit, brilliant white gives a good light, and the energy savings are massive. If you take into account the service life of 20 000 hours or more, you works save a three figure sum per bulb when you factor in purchase costs of the bulbs.
    I have a thing about blown lightbulb and the tungsten bulbs needed replacing all the time... Never lasted for more than a couple of hundred hours (supposedly 2000hrs lifetime). I felt like I was always up a ladder replacing them.
    It's a no-brainer on financial grounds, and hassle free service.
    I hate the light output and slow startup of CFLs, and need something to use in table lamps that is dimmable , so maybe halogen bulbs will do although there aren't any high wattage globe types as far as I know.
    Luckily I have a good of 60-100w tungsten bulbs, but would like to find an acceptable low energy alternative.
    Alex
    Technics SL1210| Jelco SA-750| Benz Micro ACE SM MC| Squeezebox Touch/MCRU linear PSU | Cambridge Audio 851C | High Resolution Music Streamer II+ / Linestreamer+ | Raspberry Pi 2/IQ-Audio DAC+ / Max2Play | Conrad-Johnson ET3 Control Amplifier| Conrad-Johnson LP125sa KT120 Power Amplifier| Avalon NP Evo 2.0 Speakers| Cardas Audio Quadlink-5C Speaker Cables and Interconnects| Finite Elemente Pagode Signature E-14 equipment support
  9. #29
    I'm Bob.
    Quote Originally Posted by AlexM View Post
    Alex
    Not sure on the UK (bayonet) market Alex, but I get 70w halogen screw fitting (ES?) bulbs here made by Philips. They are superb.
    They are slightly shorter in height than the original 75w Osram tungsten which are now defunct, and last time I checked were not included in the EU "green" campaign.
    May be worth checking if a bayonet version is on the UK market...
  10. #30
    The 9W Philips LEDs come in dimmable version and are the ones that I use in most places around the house. I also use on a desk lamp and the light output is quite good. It replaced a 40W incandescent bulb.
