HI Chris and Jonathan
As promised, some photos of one of a pair of AI s 1000 mk 3 50 watt class A valve amplifiers. I will post a photo or two of my Series 500 when I can release it from its place of storage. Photos now done.
Audio Innovations Series 1000 MK3 mono valve power Amplifier.
Audio Innovations Series 500 25 Watt Class A integrated Valve amplifier
This amplifier was my first true love. Used over 15 years in a number of systems and in two homes. This amplifier was designed by the legendary Eric Anderson. Eric wanted the amp to look one way and Peter Quartrup this way. I am glad Peter won but when I met Eric a few years ago at a Hi-Fi show and we talked about the design of the 500. He asked me "Does it still work ?" then with a smile he said "Do you use it with a fan ?" No I said. He told me about his concerns for overheating. This being the reason he wanted it to look another way. Like some silly Fan ...I thanked him for the amp, as it had given me years of pleasure. Thank you Eric Anderson, I am a FAN.
Amplifier with no valves in place.
Side view showing Tiffany Rcas fitted to chasis. These replaced the poor quality ones that were mounted to a very flexible board, which bent in when you attached good quality heavy cables. Sounds better too.
Front view. Tesla EL34 valves on back row. Mullard NOS yellow label EEC 83 in middle. To far left JAN Philips 6922 (ECC 88) and to far right Gold Dragon ECC83.
Rear of amplifier. Early series 500 amplifiers had three speaker output taps 4/8/16 Ohm. Later models only had two. The output transformers in earlier amps are said to be better as well.
Regards D S D L----Neil
