Here's one the traditionalists will struggle with
By ashmasher
By ashmasher
Simon
MINI DSP SHD; Longdog 300b; Reiver Fenwicks
Twitter @siashmore
I'm Shaun.
Ah an infra red effect. I do this a lot in black and white using film.
I'm Shaun.
Did you use an R72 filter to record actual infra red or is it just an effect...?
Marco will no doubt be along at some point ... Maybe he can tell us Shaun
My guess is a digital photo from a modified Nikon d70
Bingo Hamish. I think we may have covered this ground once before. The IR converted D70 is a wonderous thing.
All you need is a simple filter cut to size and twenty minutes of unscrewing things (and praying you don't get electrocuted) and then - bob's you're uncle Infrared photography at normal shutter speeds and no 'so dark you can't see the subject' filters.
There's other CS6 jiggery pokery going on too of course: channel swapping, levels, selective focus, and textures to give it the really grungy look.
S
Simon
Twitter @siashmore
