Page 6 of 9 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 85
Thread: Monitor Audio (+ News & Reviews) - At Musicraft (Derby)
  1. #51
    I have an aversion to speakers with a multiplicity of drive units. The fewer the better. Point sources rule in my book.
  2. #52
    I'm Rick.
    SoundStage visit Monitor Audio
    http://youtu.be/6VEXPlJStXE
    ***** Musicraft - Clearance + Special Offers list http://theartofsound.net/forum/showt...Special-Offers *****
    ***** https://www.facebook.com/MusicraftUK *****
    ***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
    Thanks
    Rick @ Musicraft
    Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
  3. #53
    I'm Rick.
    Hi-Fi News reviews Monitor Audio's new Gold 300 speakers
    http://ca2.monitoraudiocdn.com/downl...20150821134145
    Standing at over a metre tall the Gold 300 is a majestic three-way floor-standing loudspeaker comprising twin 6.5" bass drivers, a single 4" mid-range driver and a high frequency ribbon transducer. With such an impressive complement of drivers, the Gold 300 has the power delivery and scale required to fill the largest rooms with jaw-dropping dynamics as well as the finest musical detail. Extending from below 30Hz to over 60kHz, its frequency range is among the widest available from any speaker, regardless of price.
    • C-CAM® (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60KHz
    • HiVe®II port technology for better transient response and tighter bass
    • New C-CAM RST® (Rigid Surface Technology) bass/mid-range driver
    • Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
    • Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
    • Pureflow® silver internal cabling
    • Selected premium quality wood veneer or high gloss lacquer finishes
    • Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
    • Invisible magnetic grille fixings provide a sleek visual effect
    Thanks
    Rick @ Musicraft
  4. #54
    I'm Rick.
    Hi-Fi Choice reviews Monitor Audio's NEW Gold 200 speakers
    http://ca2.monitoraudiocdn.com/downl...20150729134008
    Gold 200, the first of new Gold's floor-standers is also the most compact. Amazing scale and impressive dynamic control are available from this slender three-way design, comprising the improved pair matched ribbon, twin 5.5" bass drivers and a 4" mid-range driver, which is housed in a dedicated enclosure. With high overall efficiency, wide bandwidth and vanishingly low distortion, the Gold 200's Platinum DNA is ready to be experienced.
    - C-CAM® (Ceramic-Coated Aluminium/Magnesium) ribbon transducer design – providing extension to a class leading 60KHz
    - HiVe®II port technology for better transient response and tighter bass
    - C-CAM RST® (Rigid Surface Technology) drivers
    - Single bolt through driver fixings for improved bracing, rigidity and driver/baffle de-coupling
    - Die-cast alloy terminal panel arrangement with high quality bi-wire terminals and high end spade type link cables
    - Pureflow® silver internal cabling
    - Selected premium quality wood veneer or high gloss lacquer finishes
    - Rigid 20mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet colouration
    - Invisible magnetic grille fixings provide a sleek visual effect.
    Thanks
    Rick @ Musicraft
  5. #55
    I'm Rick.
    Monitor Audio's new Bronze 2 loudspeakers
    Monitor Audio Bronze 2 loudspeakers
    The Bronze Two builds on the strength of its predecessor’s audiophile cred with a neutral tonal balance and high detail resolution combined with high overall efficiency and power handling. These are the perfect ingredients for compelling listening. Armed with a larger 6.5” C-CAM bass driver and front-firing HiVe® port, the turbo-charged Bronze Two is capable of effortless dynamic scale and presence, revealing all the dramatic contrast in music and cinema sound. For a speaker of its size, the Bronze Two will deliver breath-taking results mounted on a stand and placed up to 8” (20cm) from a wall.
    •New C-CAM® gold dome tweeter
    •New 6 1/2” bass driver with concave ‘dished’ C-CAM® cone profile
    •HiVe® port technology
    •Single bolt-through driver systems for increased overall bracing, rigidity and driver/baffle de-coupling
    •High quality crossovers with premium grade Polypropylene film capacitors used throughout
    •Rigid 18mm MDF construction throughout, employing radial and cross-bracing techniques for high rigidity resulting in low cabinet coloration
    •Invisible magnetic grille fixing
    •Bi-wire/Bi-amp terminal configuration
    •Premium quality vinyl veneer finishes
    Thanks
    Rick @ Musicraft
  6. #56
    I'm Rick.
    Monitor Audio's new Platinum Series 2 -
    Everything will become clear
    Experience the revealing chemistry of a purer Platinum
    All will be revealed at CES,
    Las Vegas, 6-9 January 2016,
    Suite 29-140
    ***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
    Thanks
    Rick @ Musicraft
  7. #57
    I'm Rick.
    Monitor Audio's new PLATINUM Series II has received its world premier at the 2016 CES show, (January 6 - 9, Las Vegas). The range will be on display at the Venetian Suite 29-140
    Monitor Audio's new Platinum PL500 loudspeakers
    Thanks
    Rick @ Musicraft
  8. #58
    I'm Rick.
    Monitor Audio will be exhibiting at Sound & Vision The Bristol Show (26th to 28th February) 2016 - Suite 1008 on the 10th Floor and in Room 208 on the 2nd Floor
    ***** Musicraft - Clearance + Special Offers list http://theartofsound.net/forum/showt...Special-Offers ******
    ***** Musicraft website - Special Offers list http://ww.musicraft.co.uk/special-offers/ *****
    Thanks
    Rick @ Musicraft
  9. #59
    I'm Rick.
    The Norwegian launch of Monitor Audio's Platinum Series II of loudspeakers takes place at Spaceworld Soundgarden in Oslo this weekend. Platinum PL200 II and Platinum PL500 II will be on demonstration with a full Hegel Reference 30 Series System comprising of a HD30 DAC, P30 pre amplifier and H30 mono/stereo power amplifiers
    Monitor Audio's new Platinum PL200 II loudspeakers - RRP £6299/pair
    It’s unlikely you’ll discover a more persuasive speaker than the PL100 II in its price class, but compare the floor-standing PL200 II with its smaller sibling and immediately you’ll notice the effect of four drivers in a larger cabinet. Such is the quality of Platinum II’s engineering that the character of the sound remains powerfully consistent and expressive, but with the addition of a second 6.5” RDT®II driver, the PL200 II’s bass has more weight, while its dedicated 4” RDT II midrange driver brings further definition to vocals and strings. Through the PL200 II, subtle textures are more vividly described and every note rendered with greater authority. It’s a factor of scale. Platinum II’s class-leading accuracy is a given, you simply need to match it with the size of your room.
    Monitor Audio's new Platinum PL500 II loudspeakers - RRP £15000/pair
    Measured against its peers, there is no finer audio ambassador than the majestic PL500 II. Here you’ll discover the essence of Platinum II engineering: silken layers of the finest high frequency definition suspended on an explicit midrange, seamlessly underpinned by a deep, clean and responsive bass foundation. More than ever the sound has a physical authority, conveying the ‘live’ character of instruments, voices and atmospheres as if they had materialised three-dimensionally in the air around you. This is fidelity in the raw, magnificent in stature, seductive for its rhythmic subtlety and utterly captivating in the sheer magnitude of its dynamic impact. Our most sophisticated system of no fewer than four 8” RDT®II bass drivers, twin 4” RDT II midrange transducers and MPD tweeter will render the entire harmonic sweep of every work with pin sharp timing and accuracy. Your music and film sound alive, immersive and uncompromised.
    Hegel HD30 Digital Control Center in Silver finish - RRP £3200
    Hegel P30 Reference pre amplifier - RRP £5000
    Hegel H30 Reference mono/stereo power amplifier - RRP £11000/each
    Hegel P30 and H30 Reference pre/power amplifiers
    Thanks
    Rick @ Musicraft
  10. #60
    I'm Rick.
    Monitor Audio's new Platinum Series II
    If a pin drops, you’ll hear it. When the orchestra plays, it plays for you, so vividly and with such effortless scale you’ll believe you’re ten rows from the stage. This is the magic of high-end audio as experienced through the Platinum II speakers. Whether it’s a power chord exploding from a towering backline, the majesty of a choir soaring in union or the spell-binding gravity of a solo performance, you’ll sense the chemistry of music and musician more than ever before.
    For over forty years our work as engineers and audio enthusiasts has been dedicated to this unveiling. With our most advanced driver, crossover and acoustic systems set within luxurious cabinets, we’ve tuned the virtues that have won Monitor Audio worldwide acclaim to a new intensity, allowing rarefied audio transparency to be revealed and enjoyed. Platinum II is our magnum opus, as inspirational and satisfying to us as we hope it will be to you.
    Platinum II Range
    • New RDT®II drivers with C-CAM® technology
    • MPD (Micro Pleated Diaphragm) high frequency transducer, designed in-house for Platinum II
    • HiVe®II High Velocity reflex port
    • ARC® (Anti-Resonance Composite) mid-range driver housings and baffle components
    • New patented 'DCF' (Dynamic Coupling Filter) mechanism for more natural sound
    Platinum II Craftsmanship
    The Platinum II cabinets are a statement of immaculate craftsmanship. Each is hand-built with the expert precision of the finest furniture makers, employing multiple laminations of veneer that are formed into a curved rigid shell. For the finish, natural wood veneers in Santos Rosewood or Natural Ebony are pair-matched, applied and hand-coated with 11 layers of clear gloss piano lacquer, then polished to reveal the glowing lustre in the grain. Platinum II models are also available in a penetrating piano black gloss lacquer, which will offer a luxurious contrast with room décor.
    The front baffles are hand-upholstered with the very highest quality Inglestone leather supplied by Andrew Muirhead and used to distinguish many luxury British brands. Such is the level of care lavished on the Platinum II enclosures that each requires as many as 144 hours to complete.
    Platinum II Technology
    Platinum II offers you genuine audiophile performance with stunning design and materials specification. In the pursuit of ever lower distortion, no detail has been overlooked. Through meticulous FEA modelling we’ve optimised the operation of electrical, mechanical, magnetic and acoustic systems, introducing new discoveries to meet ambitious performance goals. The Platinum II range deploys an enhanced generation of RDT® bass and mid drivers, and for the first time in a Monitor Audio product, the MPD (Micro Pleated Diaphragm) high frequency transducer. Including improved crossover and speaker terminal designs together with proprietary ARC®, TLE, HiVe®II technologies, Platinum II builds on the award-winning advances of over forty years to create a high-end speaker range that is utterly faithful to the source.
    Thanks
    Rick @ Musicraft
