Originally Posted by
YoG
FLAC and WAV will not differ in quality. Only downside of WAV is that you cannot tag the.. if thats what youre concerned about... and yup they take up massive filespace.
I'd compress them to FLAC and tag your cd's using an online database (Foobar has one built-in, and a plugin for more flexibility)
I'd also use Level 0 when you convert the Flacs.. this parameter will take up a little more more space but put less load on the cpu when playing them (0 = less compression, 9 = highest, ..smaller but eats more resources).
Also make sure your media-devices support FLAC..(mp3player, streamdevice, server etc) otherwise you can try other lossless formats, like APE or lossless WMA
