OK folks,
Have any of you fiddlers, meddlers and bodgers got any useful ideas to improve the adjustability of the VTA adjustment on the stock Technics SL1200/1210.
I have found that the only way i can get my cartridge body to run parallel with the record surface, and therefore set the VTA to where the cart manufacturer designed it to be, is by adding lots of height to the platter with the additon of mats and also be adding a headshell spacer to my ... headshell.
Can anybody tell me whether they think it would be possible to raise the current armboard somhow, possily with a spacer ring of some type, or similar device.
I the ideal world i would want to find myself in a position where i could fit a DL103, straight onto my Sumiko HS-12 with a standard thickness of mat ( possibly a felt one), and the VTA adjustmet locked down on the '3' setting with the cartridge body parallel to the surface of a 180g record...
Suggestions .... ?
