Hope you don't mind if I add my own query here, which is sort-of related. I was wondering if it's ok to bypass the plug fuses when using a distribution block. The fuse is still in the plug going to the wall socket. And IEC blocks aren't individually fused.
I intend to make my own distribution block and having the thought that the best plug and socket is no plug and socket, I am going to use solid copper busbars and screw the leads direct to them. Not the last word in practicality, but it appeals to me. And if fuses really should be used, thought about using circuit breakers. Will try the Lampizator filter which looks quite basic but is said to help.
http://www.tnt-audio.com/clinica/ttse.html
Kind Regards,
Stephen
