Results 1 to 10 of 15
Thread: Cable question
Hybrid View
Previous Post Previous Post   Next Post Next Post
    I'm Jerry.
    Default Cable question
    Can a telephone extension cable be used as an ethernet cable and if so, is there a suitable adaptor plug? I need to get an ethernet cable to where my Sky box is (as its to be replaced with something else) and routing the cable is going to be a bugger.
    Jerry
    Hifi: IPL transmission line floorstanding speakers, Squeezebox Touch, Denafrips Ares 11 DAC, DCB1 Pre-amplifier, Croft Series 7 power amp.
    Custom Hifi cables HA10SE headphone amplifier and Hifiman HE-400 headphones.
    AV system: LG 55B7, Denon AVR -x2300w receiver, Quad 12L (front) 11c Centre and 11L rear . Velodyne DD15 subwoofer.
    I'm AMusicFanNotAnAudiophile.
    Quote Originally Posted by Covenant View Post
    I'd be surprised if it worked.
    Chris
    Common sense isn't anymore!
    I used the spare wires in the telephone cable Sky put in to the Sky box to extend my wireless router. From that I connected via ethernet to the Sky box in order to use Anytime+. For Anytime+ you still need a telephone connecton so the wires that were left remained the telephone connection to the Sky box. The single telephone extension, therefore, became telephone and ethenet. You just need to make sure the internal wires go to the right pins in the connector. So the short answer is yes I think you could make it work.
    P.S. It goes without saying that you have to chop into the cable and either use the ends of old connectors like I did or new connectors.
    I'm fabulous.
    Simple answer is no. If you are having problems routing the cable then the only alternative is to consider WIFI or one of the power distribution systems.
    I have used a WIFI extender before to not only extend the range of my wifi (it was a big house) but also provide network points far away from where the internet comes into the building.
    The power based ethernet I have little experience with - but have heard reasonable reports. Read more here:
    Amazon UK
    lossless > Raspberry PI-3b+ > allo Boss > Van Damme Purple interconnect >
    Myryad Z210 CD Player > Chord Chameleon Silver+ interconnect >
    into Magnum IA170 amplifier > Van Damme Blue 4mm cable > Mission 752 Freedom Floorstanders
    Headphones: Audio Technica ATH-AD700 Open-back
    I'm Jerry.
    I am planning to replace the Sky box with a Humax freeview box (free from Talktalk). This will require a broadband connection I believe. Don't fancy the powerline thingy as it will need to be a really good connection for HD stuff.
    Looks like I will have to use the Sky telephone wire as a drawstring to pull through a Cat 5 cable. As Talktalk will charge £50 for installation should I leave it up to them?
    Jerry
    I can't see that charge covering the cost of installing a LAN cable.
    Chris
    I'm fabulous.
    It really is better if you can go the Cat5 route. Obviously, I don't know the actual problems you face (that is, distance, layout, solid floors etc?) but don't forget there is such a thing as flat cat5 cable.
    Amazon 10m flat cat5 cable
    This has been a great solution for me in the past and I am currently using a length of this running alongside a carpet gripper strip to get a network connection to my NAS box. Ordinary CAT5 would cause a ridge in the carpet... not this stuff, your wouldn't know its there at all. At my parents house I laid two lengths of this down before my Dad and I laid down some hardwood flooring - again a great solution.
    I'm Confused.
    Hi Jerry,
    For what little extra it will cost in the overall price of doing the job, I'd be inclined to go this route: -
    http://www.ebay.co.uk/itm/CABLE-PATC...item2c64e8a805
    Who knows what the future may hold in this area and you might as well be as prepared as you can be for ongoing developments. I practice what I preach in that my house (bungalow with an accessible 4' 'cellar' ) is totally wired with a mixture of Cat 5e and Cat6 as when each bit was done that was the best available at that time. I've also got a selection of long masonary drills you can borrow as well .
    Cheers,
    Dave.
    DaveK.
    My System:
    Quote Originally Posted by DaveK View Post
    Hi Jerry,
    Cheers,
    Dave.
    Just goes to show that a little knowledge is a dangerous thing Dave.
    Cat7 is the last thing on earth that Jerry needs to go near.
    The screens all make the most wonderful radio aerial if they're not properly grounded, which they won't be in a domestic environment.
    For what it's worth Cat5e is more than capable of carrying Gigabit LAN, and Cat6 is only necessary in "difficult" installations.
    I've only once had to install Cat6 because Cat5e wouldn't support Gigabit data transmission, and I suspect that the railway line running along the back of the premises was the cause of the problem.
    Chris
