ATC Engineering Goals and Approaches - Las Vegas Pro Audio
http://site.lasvegasproaudio.com/ATC...Approaches.pdf
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
Thanks
Rick @ Musicraft
Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
ATC's new SCM7 (curved) passive monitors
Thanks
Rick @ Musicraft
Musicraft should receive the first production units of ATC's new SIACD (Amplifier/CD/DAC) and their new curved SCM7 and curved SCM11 passive monitors which incorporate ATC's first 25mm HF drive unit.
Thanks
Rick. @ Musicraft
Musicraft is pleased to announce that've received the first production units of ATC's new SIACD (Amplifier/CD/DAC) and their new curved SCM7 and curved SCM11 passive monitors which incorporate ATC's first 25mm HF drive unit.
Thanks
Rick. @ Musicraft
ATC's new SH25-76 HF drive unit
Thanks
Rick @ Musicraft
What Hi-Fi - ATC launches SCM7 and SCM11 passive monitors
http://www.whathifi.com/news/atc-lau...scm11-speakers
Thanks
Rick @ Musicraft
ATC's new curved SCM7 and curved SCM11 passive monitors -
Designed for small to medium scale stereo and multi-channel applications, two new models incorporate a wholly ATC designed and built tweeter, and stylishly curved cabinets
Featuring the new ATC designed and built 25mm soft dome tweeter, updated bass/mid drivers and crossovers housed in a curved, laminated cabinet, the first of a new range of ATC closed-box passive loudspeakers has arrived. The third generation SCM7 and second gen. SCM11 are the first to employ ATC’s landmark SH25-76 tweeter, developed to satisfy the company’s long-established rigour in drive unit engineering
SH25-76 Tweeter
Sharing technology with the renowned ATC soft domed mid-range drive unit, the new tweeter employs a unique dual suspension system suppressing rocking modes even at high power output levels. The ATC configuration of a short edge-wound voice coil in a long, narrow magnetic gap ensures exceptionally low distortion throughout its operating band and removes the need for ferrofluids, which can dry out over time, compromising performance.
A complex, shaped, soft-domed diaphragm extends high frequency range and offers a smooth off-axis response. The tweeter’s 15,000 gauss (1.5 tesla) neodymium magnet has a black heat-treated top plate, which dissipates heat away from the voice coil to maintain high power handling and low power compression. A precision-machined 5.5mm rigid alloy waveguide provides optimum dispersion, a flat on-axis frequency response and resonance-free operation.
New Cabinets and Systems
Establishing what is to be a new style for ATC’s most competitively priced range of loudspeakers, the new SCM7 and SCM11 benefit acoustically and aesthetically from a curved cabinet construction. Braced and laminated for high rigidity and damping, the curved enclosures in real cherry or black ash veneer also impart a strong impression of design quality. Improved crossovers featuring metallised polypropylene capacitors, large air cored inductors and ceramic wire-round resistors offer superior power handling and clarity. Each new model exhibits an impedance curve free from low values, presenting an easy load for amplifiers of 75 to 300 watts. The SCM7 and SCM11 are designed for optimum performance without the grille – although a ull-length perforated metal grille, finished in anthracite grey to match the drive unit face plates, is supplied. According to tradition, each model number represents internal cabinet volume in litres.
Third Generation SCM7
ATC’s SH25-76 soft dome tweeter is joined by the company’s highly linear 125mm mid/bass driver. It features a 45mm soft dome - exceptional for its horizontal dispersion of mid-band frequencies - and a huge 3.5kg high-energy magnet system, which includes a 45mm flat wire voice coil, meticulously milled and formed by ATC. The magnet system and a carefully weighted doped fabric cone assembly contribute to the SCM7’s wide bandwidth, impressive dynamic range and convincing bass output - all from a tiny seven litre cabinet.
Second Generation SCM11
The new SCM11 features ATC’s SH25-76 with an ATC CLD 150mm mid-bass driver incorporating a 45mm soft dome. Constrained Layer Damping is a driver cone technology exclusive to ATC and represents a step-change in driver-to-system performance. Advantages include reduced harmonic distortion between 300Hz and 3 kHz, an extended frequency response that eases constraints on the crossover filter slope, and improved off-axis response.
Manufactured in-house, the new SCM7 and SCM11 offer the ownership of a hand-built ruggedly engineered speaker, world famous for musical accuracy and high power output. Like all ATC products, the new models are backed by a six-year warranty.
Thanks
Rick @ Musicraft
ATC custom designed and built active tri-amp packs for Dolby Labs newest screening room at one of their offices in Sunnyvale, CA, USA
5 of these amplifiers were used to run 18 custom surround loudspeakers for Dolby's new Atmos surround system.
Thanks
Rick @ Musicraft
Thanks
Rick @ Musicraft
ATC will be showing the SCM110ASL Pro loudspeakers at the Audio Engineering Society annual US convention in October. The convention is taking place from the 17th - 20th October at the Javits Convention Centre in New York. We'll be there along with our US distributor, TransAudio Group.
Thanks
Rick @ Musicraft
