ATC P2 300w/ch dual mono power stereo power amplifier description, features and specifications -
Generating twice the power of its smaller P1 sibling, the P2 will drive the most challenging loudspeakers with ATC’s signature virtues of wide bandwidth and ultra-low distortion…
ATC's new P2 300w/ch dual mono power stereo power amplifier is at Musicraft (Derby)
ATC P2 power amp modules
Musicraft's new P2 300w/ch dual mono power stereo power amplifier at ATC
ATC, Acoustic Transducer Company, is a specialist British manufacturer of loudspeaker drive units and complete sound reproduction systems, including the relevant electronic equipment. ATC designs and manufactures the finest and most accurate of monitors in the world. ATC achieves this by designing and manufacturing loudspeaker drive units and systems to achieve levels of performance far in excess of the industry norm. ATC has kept to its aims of building loudspeakers and electronics which employ the most effective of modern engineering principles. ATC don't respond to competition, instead ATC responds to advances in technology that enables ATC to improve their products. ATC's goal is to have loudspeakers as near perfection in performance as possible by having the lowest possible distortion.
By selecting ATC you join a group of music lovers, professional audio engineers, educators, studios, and musicians across the world that understand the value of the engineering that goes into every ATC product.
ATC’s products are installed at some of the world’s most prestigious multi-channel studios and auditoria. Where ever the best is required you will find ATC.
http://vimeo.com/107575611?from=outro-embed (ATC's 40th Anniversary Celebration video)
http://atcforums.co.uk/pdf/ATC%20CORP%20BROCHURE.pdf (ATC Corporate brochure)
ATC Transducer. The sound of accuracy. Naturally.
Hand-built by ATC in the UK, the P2 class A/B stereo power amplifier is designed to complement the brand’s range of hi-fi preamplifiers, both aesthetically and operationally. Rated at 300W continuous power per channel and developed in tandem with the P2 Pro studio amplifier, the ATC P2 is a Dual Mono design, keeping the power supplies, signal and return paths discreet. This approach ensures that the amplifier will achieve the maximum signal separation with minimal crosstalk, and that intermodulation between channels via the power supplies is reduced to an absolute minimum across a frequency range of 400kHz. It also means that the power delivery from one channel cannot affect the specified power available from the other.
Within a new low-vibration chassis design featuring a precision machined 12.7mm brushed aluminium front panel, the P2’s layout includes a massive, custom-made 400 VA low-noise transformer for each channel and an output stage involving 3 pairs of MOSFET devices per channel to achieve peak current output of over 15 amps. ATC’s unique “grounded source” output stage ensures smooth power delivery and extremely low harmonic distortion. The gain of the P2 matches that of the lower power P1 (150W/ch) so that they can be used together in bi-amp or tri-amp systems, connected via the amplifier ‘Link’ phono inputs/outputs.
The ATC P2 offers balanced XLR and unbalanced phono inputs, ‘link’ phono outputs, proprietary 4mm speaker terminals, and IR remote control.
ATC P2 Features -
• Latest ATC discrete MOSFET grounded source output stage.
• Class A/B topology.
• 300W into 8 ohm continuous power O/P capability
• Dual mono-design ensures minimal crosstalk and inter-channel modulation.
• Entirely separate power supplies for high voltage audio, low voltage audio and logic/control.
• 400kHz bandwidth to ensure best possible transient reproduction.
• Vanishingly low distortion.
• Custom low noise toroidal transformers.
• New chassis design for reduced vibration and a more striking visual appearance.
ATC P2 Specifications -
• Max Continuous Output Power : 300W (8Ω, 1% THD)
• Input Sensitivity : 2V rms (ref. 150W out)
• Input Impedance : 10kΩ/leg
• Frequency Response : <2Hz – >400kHz (-3dB)
• Signal to Noise Ratio : >110dB (DIN)
• Crosstalk : >100dB
• THD : >0.002%/-95dB
• Dimensions (HxWxD) : 141x448x337mm (5.6˝x17.6˝x13.3˝)
• Weight : 30kg / 66lbs
• 6 year warranty
ATC P2 RRP £3120
ATC SCM100ASL Professional Monitors used here at Musicraft (Derby)
ATC SCM100ASL Professional monitors
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://www.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
