ATC curved SCM19 passive monitors - What Hi-Fi Award Winner 2016 for the best standmount speaker £1500+
http://www.whathifi.com/atc/scm19/review
“If you value insight and honesty above all else, these speakers are a terrific buy”
ATC curved SCM19 passive monitors in Cherry finish
Featuring the new ATC designed and built 25mm soft dome tweeter, updated bass/mid drivers and crossovers housed in a curved, laminated cabinet, the first of a new range of ATC closed-box passive loudspeakers has arrived. The second generation SCM19 employs ATC’s landmark SH25-76 tweeter, developed to satisfy the company’s long-established rigour in drive unit engineering.
ATC, Acoustic Transducer Company, is a specialist British manufacturer of loudspeaker drive units and complete sound reproduction systems, including the relevant electronic equipment. ATC designs and manufactures the finest and most accurate of monitors in the world. ATC achieves this by designing and manufacturing loudspeaker drive units and systems to achieve levels of performance far in excess of the industry norm. ATC has kept to its aims of building loudspeakers and electronics which employ the most effective of modern engineering principles. ATC don't respond to competition, instead ATC responds to advances in technology that enables ATC to improve their products. ATC's goal is to have loudspeakers as near perfection in performance as possible by having the lowest possible distortion.
By selecting ATC you join a group of music lovers, professional audio engineers, educators, studios, and musicians across the world that understand the value of the engineering that goes into every ATC product.
ATC’s products are installed at some of the world’s most prestigious multi-channel studios and auditoria. Where ever the best is required you will find ATC.
http://vimeo.com/107575611?from=outro-embed (ATC's 40th Anniversary Celebration video)
http://atcforums.co.uk/pdf/ATC%20CORP%20BROCHURE.pdf (ATC Corporate brochure)
ATC Transducer. The sound of accuracy. Naturally.
ATC curved SCM19 passive monitors in Satin White finish
ATC curved SCM19 passive monitors in Satin Black finish
ATC SH25-76 HF Unit
Sharing technology with the renowned ATC Soft Domed mid-range drive unit, the new tweeter employs a unique dual suspension system suppressing rocking modes even at high power output levels. The ATC configuration of a short edge-wound voice coil in a long, narrow magnetic gap ensures exceptionally low distortion throughout its operating band and removes the need for ferrofluids, which can dry out over time, compromising performance.
A complex, shaped, soft-domed diaphragm extends high frequency range and offers a smooth off-axis response. The tweeter’s 15,000 gauss (1.5 tesla) neodymium magnet has a black heat-treated top plate, which dissipates heat away from the voice coil to maintain high power handling and low power compression. A precision-machined 5.5mm rigid alloy waveguide provides optimum dispersion, a flat on-axis frequency response and resonance-free operation.
ATC SH25-76 HF Unit used in curved SCM19 passive monitors
ATC's security guard
ATC’s SH25-76 soft dome tweeter is joined by the company’s highly linear 150mm mid/bass driver. It features an integrated 75mm soft dome – exceptional for its horizontal dispersion of mid-band frequencies – and a huge 9kg high-energy, ‘Super Linear’ magnet system, which includes a 75mm diameter flat wire, underhung voice coil, meticulously milled and formed by ATC. The magnet system and a carefully weighted doped fabric cone assembly contribute to the SCM19’s wide bandwidth, impressive dynamic range and convincing bass output coupled with very low distortion as a result of the unique ‘Super Linear’ motor system.
ATC SB75-150 SL mid/bass drive unit used in curved SCM19 monitors
Second Generation SCM19 - New Cabinets and Systems
Establishing what is to be a new style for ATC’s most competitively priced range of loudspeakers, the new SCM19's benefit acoustically and aesthetically from a curved cabinet construction. Braced and laminated for high rigidity and damping, the curved enclosures in real cherry or black ash veneer also impart a strong impression of design quality. Improved crossovers featuring metallised polypropylene capacitors, large air cored inductors and ceramic wire-round resistors offer superior power handling and clarity. The SCM19 exhibit an impedance curve free from low values, presenting an easy load for amplifiers of 75 to 300 watts. The SCM19 is designed for optimum performance with the grill in place – although the difference in performance without the grill is minimal. The metal grille, finished in anthracite grey, fixes to the cabinet via hidden magnets. According to tradition, each model number represents internal cabinet volume in litres.
ATC SCM100ASL Professional Monitors used here at Musicraft (Derby)
ATC SCM100ASL Professional monitors
***** Musicraft - Clearance + Special Offers List http://theartofsound.net/forum/showt...Special-Offers *****
***** https://www.facebook.com/MusicraftUK *****
***** Musicraft website - Special Offers list http://ww.musicraft.co.uk/special-offers/ *****
Thanks
Rick @ Musicraft
Musicraft is Derby's foremost dealer for the finest, specialist Hi-Fi, Home Cinema & Multimedia components/systems. So, if you would like to know more about how our products can enrich your life, then please visit us or contact Rick.
