Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Polishing my lid
    I'm Simon.
    You can, but it takes many hours.
    I'm arecurringnightmare.
    Oh Yes you can.
    Use 800 wet and dry, move to 1200,then use a rubbing compound and finally a metal polish, hey presto, nice shiny lid LIKE NEW.
    Just my two cents worth, i'm working with Perspex as a material for some design work I'm carrying out.
    Charles
    Acer Laptop/Foobar/WASAPI/S/PDIF/DacMagic/Mini T/Mission 754
    any deck I use I always take the lid off permenantly and stick it in a cupboard - they ruin the sound if you leave them attahced and they get in the way when using the deck.
