Is it possible that some cdr discs are thinner than others. I believe some laser mechanisms are quite sensitive to this. Maybe if the track the laser moves along is worn it would exacerbate this.
Sitting comfortably?
Please click on the YouTube link below for further information.
http://uk.youtube.com/watch?v=wN5EjwcE8HM
I havent edited the clip and the sound cuts out when the camera moves next to the speaker.
The CDP hasnt failed to read the TOC for quite sometime.
If I were to purchase a replacement laser would it be worth modifying this player or would I be better off sourcing a unmodified Marantz CD63?
Any suggestions?
Richard
Why not source another Arcam Alpha 7?
Ben Duncan mains conditioner
Samsung QE75Q90T 75" QLED TV
Atacama SE24 stands
Hehehehe, your production and camera work was so good that I ate it all on the second play through.
Your 7 is definitely not in a good way and it sounds like the end of the road unless you want to invest time and/or money sorting it out. It may be the time to look elsewhere as you've suggested. The CD-63 is a good player but not really much better than your 7 in unmodified guise.
What's you budget?
Atacama SE24 stands
Pioneer DVD575 sounds preferable to many budget CD players, and makes a good transport. To my ears anyway.
Playstation One model 1002 with simple modification is worth exploring. If not the most convenient solution.
Good choice Alb, if it's good enough for Max Townshend, it's good enough for most.
Atacama SE24 stands
Why are you writing posts on how to use copied music buy originals.
Copys are poor anyway especially if you have a decent system that is capable of showing difference
*** Post edited by Filterlab ***
Gary, just because a CD may be duplicated does NOT mean it is necessarily illegal.
Atacama SE24 stands
