Great,
now you've got the cartridge sorted any plans for a new turntable ?
I'm Mark.
Great,
For now I will be content with the modded SL-1210 Mk5 w/SME 309 arm.
I will probably put another phono cable on it since I have read that is one of the weakest points of this arm.
Now I just need Dave C. to send the the 309 arm
Not sure what turntable will soundly beat the 1210 when it is properly modded and isolated. Anyways there is no money for that now
Hearing is believing
SL-1210 Mk5 w/Mike New Platter/bearing/armboard; Hynes SR5 DIY PSU;
Zyx Airy3X; SME V; Hashimoto HM7 SUT; CJ PR15MkII Phono w/teflon caps.
Modwright LS36.5 Dual Mono Preamp & KWA 150 amp > Paradigm Ref 100 v.4s
With the above attended to and a cartridge like yours on it, I don't think you've got anything to worry about!Not sure what turntable will soundly beat the 1210 when it is properly modded and isolated.
The airy 3 is a great choice
Listening to the Zyx Airy3 now Big step up from the Denon DL160.
Bigger soundstage, much more resolving, deep bass, more extended highs, and much cleaner sounding.
When I installed it I forgot to switch the loading resistor and still had the Pearl phono set up for the 47kohm cart loading. I think the cart is almost unstable electrically (feedback) with this load. Just moving the tonearm I could hear vibrations in the cart/tonearm coming from of the speakers. And putting it on the record and off I got a huge pop, one of them put my amp into some sort of thermal protect mode, I think (got a loud popping noise repeating about 1-2 times a second, scared the sh*t out of me.)
Anyway I let the amp rest for about 20 minutes. Then I remembered the loading resistor. Switched to 100ohms, and everything worked normal again when I turned everything back on. No more cart feedback/noise from vibration on the cartridge and the amp was okay, as well as my speakers. T
That was spooky.
