I've used both Kontak and Deoxit and prefer Deoxit. The latter in a spray can will last for years and works extremely well. Why buy a cheaper product of questionable merit?
Robbie: use the included tube to direct the spray carefully and use only on plug/socket contacts, switches and rotary controls. A small amount is all that's needed and then work the switch/rotary to get the fluid well into the contact surfaces. You should end up with controls that make no noise when operated.
Have found these to be useful for getting into tight spots.
Spray some cleaner into a plastic top (like those on pressurised cans) and then you can apply cleaning fluid just where it's needed.
Sent by me using an appendage
SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
Luxman 509X amp.
PMC 25 23i speakers.
Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
Cables by Kimber, Yannis and Audioquest.
Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
Thanks Neal / Martin, I'll go carefully
