Results 1 to 9 of 9
Thread: Yamaha GO44 Music interface
    Default Yamaha GO44 Music interface
    Well,
    At last I have just picked one of these up off ebay, unused, still in its box, at a good price. I understand that amongst many other things it is quite a useful DAC which will enable me to connect my Macbook via the firewire port to my system and can give very good results.
    I already have plenty of music on an external drive in Apple Lossless, basically as a back-up to my ipod and hopefully with time I will learn to exploit its possibilities with higher res files, but for now any tips on how to set-up my Macbook for use with this gizmo to max performance on playback through my system would be much appreciated
    I am essentially a vinyl only person at home who happens to use an ipod as a library for my car player but I will now be able to scratch the surface of this digital lark a bit.
    Cheers,
    Chris
    I'm BigBobJoylove.
    Hi Chris, can you tell me what Macbook you're using, the specs and OS etc.
    Ta.
    Ben Duncan mains conditioner
    Samsung QE75Q90T 75" QLED TV
    Atacama SE24 stands
    Hi,
    Itīs a Macbook 2,1 running OS 10.5.3, 2GHz Core 2 Duo with 1Gb 667Mhz DDR2 and SDRAM - the heavy one that always looks dirty.
    whatever all that means.
    Default Paging Filterlab
    Is your silence thru lack of time or after seeing my specs, have I dropped one ?
    I'm BigBobJoylove.
    Haven't had a moment to look at it yet to be honest, will have a look as soon as I can.
    Atacama SE24 stands
    Cheers Rob,
    Iīm away on business next week so no sweat at all.
    Thanks in advance,
    Chris
    I'm BigBobJoylove.
    Firstly you need to ensure your Audio Midi set up is correct, look for Audio Midi through Spotlight and open it. Depending on the music files you listen to (i.e. whether they're 16/44.1 files ripped from CD or 24/96 files downloaded from a high resolution music provider), simply set the sample bit rate and frequency to match the source. If these are exactly the same then it will remove any potential for aliasing and the associated jitter and distortion. The DAC will automatically alter its input to match the Mac's output. Audio Midi should look as below:
    Atacama SE24 stands
    Hi Rob,
    Well, Iīve got it working but I donīt know if itīs right. Do all manuals for such things just assume we are all studio engineers and donīt need instructions ?
    When I go to my audiomidi set-up as you suggested, the page I get is like a mirror image of the one you included in your post i.e left is right and right is left. Where yours says "input is not supported" on the left, mine says "output is not supported" on the right. ??????
    When I go to the GO44 control page, it says "input for phones" is DAW1/2. Apparently DAW is digital work station ?????? but when I change it to digital in no sound comes out asm I have checked via the built-in phones output. Sounds considerably clearer than the ipod/macbook phones output.
    Anyway, as I say sound is forthcoming so I shall knock up the right cables to enable connection to my system this weekend and see how it goes.
    I find it highly ironic that in the age of I/T and knowledge at our fingertips, the bloody manufacturers donīt bother making comprehensive instructions. Suck it and see, I guess.
    I'm BigBobJoylove.
    Quote Originally Posted by Chris View Post
    Hi Rob,
    Yes, and they always have. Your GO44 is intended for professional use and therefore the manual is written assuming a certain level of knowledge. You think that's bad, you should see the user manual for a professional synthesiser workstation.
    Interesting, sounds like the GO44 is taking care of the output (as it should) and since it's an output device only then it should say 'output is not supported'.
    When I go to the GO44 control page, it says "input for phones" is DAW1/2. Apparently DAW is digital work station ?????? but when I change it to digital in no sound comes out as I have checked via the built-in phones output. Sounds considerably clearer than the ipod/macbook phones output.
    Sounds like it's working fine. If you have audio output then the digital source (playback software) is communicating with it seemingly with no problem. Adjust the settings so that the audio is audible and leave it at that. Experiment with them if you feel something is not right, but nine times out of ten the automatic settings are usually the most ideal.
    Good luck!
    I refer the honourable gentleman to my first comment.
    Atacama SE24 stands
