Sent by me using an appendage
SME Model 15/V tonearm, Lyra Dorian, EAR Phono Box.
Luxman 509X amp.
PMC 25 23i speakers.
Innuos/Roon/Qobuz/I-Pad. Oppo UDP-205.
Cables by Kimber, Yannis and Audioquest.
Audioquest Niagara. Tube Distinctions Mains power filter. Project RCM. Zerostat.
Luxman 509X amp.
Cardiff tried to phase it out in the early 90's, then dance hit mainstream and it came back big time. Around 2006 they then phased it out after having quite a good selection to be fair.
Couple of months ago it came back. A whole isle (one side) of mainly rock 180gram re-issues......which is better than none at all of course
No dance singles though
I'm ChrisB.
HMV in Lancaster started stocking vinyl a couple of months ago. I went & had a look out of interest (normally I'd not darken their door) & found maybe a couple of hundred titles, mostly biggish sellers from the past, priced in the 14-25 quid range. I was rather pleased to find one or two fairly lesser known things too - including Big Star's 'Radio City'. However the staff, rather exposed their lack of knowledge as they had it filed under 'R'. I moved it to the 'B's' & the little twerp put it back while muttering "R for Radio City"
Last year i bought a copy of lal Watersons album Once in a Blue Moon from Oxford street only to find it damaged. i took it back only to find it back on the racks a week later.
Technic 1210, PS3, AVI neutron 2.1, Icon Audio p1 phono stage.
I wouldn't buy from HMV Belfast in a fit.....they have no clue how to present or look after vinyl. Their pricing strategy is nearly as bad as a few 'Hi End' hi fi design houses lmao.
Head have gone but word for those in the know is that they will return rather soonish....watch this space.
ECM vinyl in HMV = upwards on £30 sometimes.....can be had from ECM for an awful lot less direct!
Steve
Never let anything cause you to doubt your ability to demonstrate the truth.
