For Sale - REL Q150e mkII subwoofer.
This is my REL Q150e MKII sub for sale in excellent condition.
It comes with original box, instruction manual, mains lead an Neutrik high level connection cable.
Condition is very, very good, with only very minor scuffs and a couple of mini snags on the grille material (right on the bottom edge - can't be seen when sub is on the floor).
This is the 150W version that is suitable for A/V or stereo use, thanks to it's low-level or high level inputs and slam/depth modes. Allows you to quickly and easily tune the sub to your room and main speakers.
The Neutrik cable is included to allow you to connect the sub to the speaker terminals of your amplifier. Comes with original box, manual and leads.
These go for around £160 on ebay plus P+P. Collection is preferred, P+P would be around £20.
From the REL website - Q150E Mk II
Ultra-compact sub-bass system designed for use singly or in pairs with high quality compact satellite loudspeaker systems.
- True 150W (continuous) discrete, direct-coupled MOSFET amplifier
- Upgraded forward-firing long-throw 250mm (10") steel chassis driver
- Improved ABC® filtering circuit
- Four position mode selector: line/LFE (0 degrees phase and 180 degrees phase)
- Audiophile grade toroidal transformer
- Slam/depth switch
- High quality, gas-tight Neutrik Speakon input (high level)
- High quality, panel-mounted twin phono inputs at 0dB and +12dB (low level)
- Totally discrete input circuitry for high and low level inputs
- Separate volume controls for high and low-level adjustment
- Simultaneous connection of high and low level sources
- Set-Safe® audibly transparent driver protection
- Double-sided glass-fibre board with plated-through holes
- IEC power input socket - no captive leads for installation flexibility
- Finished in Brittex black in three separate coats with grille
- Nylon studs and 8mm spikes supplied
- Hand-built in Great Britain.
Specifications
System Type
Active ZeroQ Acoustic Suspension System with ABC® variable bass filter. Closed box, 13 litre.
Frequency Range
30Hz-100Hz
Amplifier Input impedance High level 100 kOhm
Gain Control Range
Low level 10 kOhm
80dB
Drive unit impedance
4 ohm
Mains input voltage
115 V 50/60 Hz or 230 V 50/60 Hz, subject to country
Dimensions WxHxD mm (inches)
incl. feet and rear panel controls
290x318x330 (11.43 x 12.53 x 13.01)
290x290x330 (11.43 x 11.43 x 12.61)
Weight Kg (lbs)
11 (24.25)
Finishes
Brittex Black
Martin
Source: Sonos CONNECT
DAC: Rega DAC
Amp: Rega Brio-R
Speakers: Neat Motive 2.
My system photos
Bump - any serious offers considered.
Martin
Martin
DAC: Rega DAC
Amp: Rega Brio-R
My system photos
Martin
DAC: Rega DAC
Amp: Rega Brio-R
My system photos
Martin
DAC: Rega DAC
Amp: Rega Brio-R
My system photos
- You may not post replies
- You may not edit your posts
Forum Rules
