Results 1 to 10 of 15
Thread: My setup
    Default My setup
    My system has looked far better than this. noteably when it was MF/cyrus icons and orbe. However, it's never sounded better than it does now.
    there's a lesson in there somewhere
    the standac is hidden behind the ps1200. i really need an extra shelf module but can't find one
    recovering audioholic
    Technics: SL 1210 mk2 / KAB PS1200 psu /Trans-fi Terminator / AT-OC9MLII / WD ph3s /Bluesound node 2i/Musical Fidelity Ms3i/ WADkit 6550 / Tannoy revolution xt8f
    Gareth.
    Excellent, Gareth - some nice kit there...
    How are the 'bits' I sold you doing?
    rumbled - this is an old photo hence the lack of damper. i'll pop an extra one up in a mo.
    the damper is doing its job nicely and is a nice piece of engineering.
    the transparent lead is less of a revelation if truth be told, but i don't think it's any fault of the lead.
    i think the most suprising thing in the entire setup is the sony NACdh1e
    i don't know what it does in there, but output from its HDD is almost imperceptible from the output through the TC-7510 6/4 and transparent i/c.
    there is a difference, but nothing mindblowing.
    i think a lot of people would consider the sony a 'toy' - i can honestly tell you it's an excellent bit of kit, and i'm very glad i found it at such a good price.
    Gareth.
    LOL, no worries! I thought that I couldn't 'spy' the damper
    Cables will do what cables will do from system to system... There is no 'one size fits all' cable.
    Have you made sure that directionality is correct? The end marked with the white collar on the plug goes to the source, etc. If not, it won't sound right.
    It's all ticketty boo fella. it's horses for courses as you say. the 'logical' step would be to address the analogue i/c from the dac/cdp but i don't wish to go down that road again just yet.
    Gareth.
    You know, I was offered a Transparent ML Ultra balanced in fully working, but tatty cosmetic condition for £200 a number of years ago. I didn't have my cheque book and before I got the chance to re-visit the chap I was made redundant from the "road" job I had!!!!! I feel deep regret as I really liked their Ultra interconnects, despite the boutique prices. A mate has his Krell/MLsystem wired with Transparent Reference leads with no guilt whatsoever lol.
    How do you find that mitchel clamp? They look pretty cool. Any use or just purdy?
    I dont currently use it in conjunction with the sds. i'll be using it again when i get a different mat.
    it's light, it works, it looks good and it's cheap
    give it a go
    Gareth.
    what mat are you thinking of using with the clamp?
    Does the clamp clamp to the spindle? I've never used one before- can you clamp it down too hard and make things worse?
    Quote Originally Posted by fraser. View Post
    hopefully a herbies mod or srm. the sds does a good job but has to be used in conjunction with something to provide a decent record/mat interface.
    it clamps on to the spindle. it pushes down as hard as you want really. damage is easily avoided. like i say, if the disc is perfect then no clamp should be required, i just like using them
    Gareth.
