Yes I'm doing it with a non spinning record as mentioned. There are only a limited number of things you can do to get it level
1) Adjust the vta. This doesn't resolve it.
2) Twist the headshell slightly. This doesn't resolve it either. I've read people talking about twisting the cart itself but I really can't see how this works. Once the screws are done up the cart will only sit in one position securely.
The tonearm spirit level implies that (as you look down the 'barrel' of the cart/arm) that the left (inner) side of the cart is higher than the right (outer) side of the cart.
But I cannot see how I can resolve this
Edited to say there is one thing that springs to mind that may have caused this. I lost one of the original nuts that go on the bolts supplied with the headshell to hold the cart. So I sourced one from elsewhere. It fits perfectly and looks the same thickness to the naked eye. Could it be that it's thickness is marginally different?
System:
SL1210 > Whest PS 3.0RDT> Audio Research LS17 pre> Lyngdorf RP1 room correction> Lyngdorf sda 2175 > Monitor Audio Platinum 300 speakers
