Page 3 of 24 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 234
Thread: Sounds light on bass
  1. #21
    Lol - well yours is a much higher quality AT cartridge, on a very different T/T (modification-wise) from David's! Besides, you might think that until you heard the difference, say, a Zu or Denon DL-103SA made, in comparison
    also I dont think my speakers are quite as efficient as your Tannoys, never heard any Zu or Denon's so i might just be surprised.
    PRE
  2. #22
    I'm Andy.
    l have had a couple of carts recently and they both sounded anemic compared to my Stantons ( this includes my Nagaoka MP110) which is quite a full sounding cartridge.
    Me so horny- Impulse H6 Horny
  3. #23
    I'm david.
    Thanks for all the input guys.
    I got home late (again) from work but did have about an hour to have a play. This is what I did and found
    1) Listened to the sumiko head/at 440 cat again. It did still sound very light on the bass. Everything else sounded good ie detail, imaging etc, but very light on bass
    I reset the balance on the arm with this set up. Tracking force and anti skate set to 1.5
    Still sounded the same
    2) Swapped it for the tech original headshell/stanton 500 cart and set up the tonearm. Tracking force/anti skate at 2. The fuller sound is back with decent bass. Not as refined as 1) and sometimes control is lost at the extremes in terms of the bass but generally a much fuller sound. Or as somebody (?Marco) described it, less 'anaemic'
    (VTA was set by eye for both, I'm awaiting my tonearm spirit level to do this more accurately)
    This can only mean one of two things
    a) This is just the inherent sound of the AT cart in my set up (Something Marco warned me about)
    b) The AT cart is 'damaged'. I did manage to very slightly perforate the black plastic shrink wrap of the white litz wire such that I can see the silver wire through it. This would probably be unlikely to be the cause.
    Assuming a) is the issue then I still need to find the right cart. I need something with the bass slam of the Stanton but with the added refinement/detail/imaging of the AT.
    A cart that doesn't lose control of the bass as the Stanton does sometimes but also doesn't try and resolve this issue by just sucking out all the bass as the AT seems to do.
    Just to be clear I'm not one of those people who listens to distortion or a things rattling and thinks that's great bass. But I want accurate, well controlled bass. I chose large 4 driver speakers because I know they can produce exactly this.
    I just need the right cart!
    Thanks to all for your help
    System:
    SL1210 > Whest PS 3.0RDT> Audio Research LS17 pre> Lyngdorf RP1 room correction> Lyngdorf sda 2175 > Monitor Audio Platinum 300 speakers
  4. #24
    David,
    Buy a Nagaoka MP200, and trust me, your cartridges woes will be over:
    http://www.musonic.co.uk/mp200-cartridge-p-83.html
    There is where your ideal balance of sonic virtues lies... Strap her onto your Sumiko, and then bask in vinyl heaven!
  5. #25
    I'm david.
    David,
    Thanks Marco, I would have been better off trusting you in the first place as I think you warned me about this happening
    However as I can't afford to buy another unsuitable cart I need to proceed with caution.
    The blurb on the net says the MP200 is 'ideal for classical and jazz music' and as you know I don't listen to that genre.
    Are you sure it will cope with my dance music fetish and give detail, imaging and the thumping but controlled bass line that my ears yearn for?
    Thanks again
    System:
  6. #26
    MartinT Guest
    If you like the sound and weight of the Stanton, why not buy a more upmarket model like the 681EEE?
  7. #27
    I'm Allthatwasisorwillbe.
    Hi david,
    I don't know what your budget is,but if marco is suggesting the Nag mp200 then it's a fair bit by the looks of it.
    If so my suggestion would be this tone arm http://www.ebay.co.uk/itm/Jelco-SA-7...item4164bbba03
    Then try to find an original US made Shure SC35C or get an Goldring G800 retipped.
    I have the jelco and shure combo and listen to mainly electronic dance type music,and trust me no issues with lack of bass Here's a write up on both carts by marco and some of my waffling http://theartofsound.net/forum/showthread.php?t=12745
    Just something to consider
    Darren
    KORUS CUSTOM SERVER
    TECHNICS 1200 MKII_JELCO 750D_SHURE SC35C (with NOS and NEO SAS styli)
    CAIMAN SEG + DORADO PSU
    CROFT MEGA MICRO
    PARADIGM REFERENCE ACTIVE/40'S
    PARADIGM SERVO 15 SUBWOOFER X 2
    ''The theory of relativity is a mass of error and deceptive ideas violently opposed to the teachings of great men of science of the past and even to common sense''
  8. #28
    Hi David,
    Yes, I also read that. Ignore it, as it's simply advertising blurb, designed to sell the product to its target market. 'Audiophiles', after all, tend to listen to jazz and classical, rather more than dance music... The website is hardly going to say: 'Dis bad-boy is perfect for thumpin' out some bangin' tunes'!
    More seriously, if a cartridge excels with (highly demanding) jazz and classical music, you can bet your boots it'll handle dance music with equal aplomb!
    The reason I picked the MP200 is because it's an extremely capable cartridge, and the highest 'SPPV' (sound-per-pound value) option in the current Nagaoka range, which basically means that the more expensive models in the range will only give a small percentage of improvement over it (the law of diminishing returns).
    The better Nagaokas in the current range, such as the MP200, have the 'balls' of the Stanton and the refinement of the AT, due to the extreme high quality of the styli they use, and the cartridges also work very well indeed on the stock Techy arm, therefore the MP200 should provide you with the best of both worlds.
    Do some research on Nagaoka, as a company, and you'll discover just how special and unique their in-house design skills are... Once you've done that, shop around for the best price for an MP200, as Musonic may not be the cheapest.
    Martin also makes an excellent suggestion, with the Stanton 681EEE MKIII. As such, you may find this thread of interest: http://theartofsound.net/forum/showthread.php?t=4095
    The best place to buy one is from Juno: http://www.juno.co.uk/products/stant...lus/308807-01/
    The decision is yours. Either cartridge will be a huge step-up on what you're using now. Ultimately the MP200 will have more class and refinement, due to its superior stylus, but the Stanton will give you about 85% of the performance of the Nagaoka, for rather less expenditure.
    My advice? If you can afford it, go for the Nagaoka, as overall, it'll put a bigger smile on your face. It'll also stand some significant upgrades in the tonearm department, and so it would be a cartridge you'd not need to upgrade for quite a while
  9. #29
    I'm david.
    Thanks Darren, I was trying to hold off uprating the arm as yet. My plan was to get a nice cart for now, then a psu and finally if funds allowed going for a funk firm or OL silver tonearm.
    Martin that's a good idea re; stanton 681EEE.
    I think it's a toss up between the stanton 681 EEE and the Nagoaka that Marco recommended. Having never had heard either any guidance would be appreciated.
    Marco, you have pm
    System:
  10. #30
    And you have a reply
    Here's some interesting info on Nagaoka, as a company: http://www.nagaoka.co.jp/product/index_e.html
    Have a read about their diamond machining technology - it's rather enlightening and gives an intriguing insight into the kind of expertise that they have at their disposal!
