Page 11 of 24 FirstFirst ... 91011121321 ... LastLast
Results 101 to 110 of 234
Thread: Sounds light on bass
  1. #101
    The reason I wasn't planning to change the tonearm yet is that I read the stock one wasn't that bad and should be further down the priority list of mods.
    It's not bad, within its limitations, and far from the worse thing on the turntable, as standard (the mat and feet come into that category). As usual, the results you get are largely governed by how much you're willing to spend.
    You have my advice now on how to proceed from here. The fact is, you could have the most optimally set up AT 440 on the planet. It would matter little, as you don't like how it sounds in the context of your system.
  2. #102
    hi All,
    I think Marco has hit the nail on the head, i used an AT440ML in my Rock turntable for a while [which by the way is not known for being bass light] and although like many i marveled at its information retreival and exceptional tracking capabilities,i always found it a bit forward sounding and the mid range a bit weak, although this might not be the case in every system it was my findings and it did change slightly depending on weight and set up, but its over-all sonic presentation remained.
    A...
    Nikola Tesla
    www.tubedistinctions.co.uk
    Matthew 5:10
  3. #103
    I'm Deleted.
    Blimey David, you've been quite generous with the credit card on the rest of the system, but when it comes to the TT you've become Mt Thrift (which is quite the wrong way round)! As a result, you've ended up with a right mullet - just buy the blooming cartridge Marco has recommended (though personally I haven't heard a Nagoaka in 20+ years) - it's a pittance compared to what you have spent on other components! Alternatively, bite the bullet and upgrade the deck properly, get a new arm and fit a decent MC cartridge.
    Account Deleted
  4. #104
    MartinT Guest
    Quote Originally Posted by indus View Post
    Are we all sure that nothing is being over looked? Could I have done something really stupid in the set up that has caused this? Would any further photos help?
    David - can you definitely confirm that the arm's VTA adjustment will not go any lower?
  5. #105
    I'm Paul.
    I think I have been hinting at this a number of times with no response. Get your wallet out David and audition some of my suggestions, That system probably would accomodate something much more exotic even. I think you have been a bit swayed by the Techie fanboys on here.
  6. #106
    Hi Paul,
    On the contrary, David has already explained exactly why he's done what he's done:
    My reasoning for buying it was that I could really test the SL1200 hypothesis ie that with some well thought out mods it can perform to a high level. With the Whest in the chain I would know that nothing else is holding it back (ie I already have decent preamp, amps, speakers etc)
    The plan was to throw some money at the Tech and see if I could hear improvements. If I could then I'd continue down that road and spend more on it. If I couldn't hear improvements then I'd strip the Tech back to standard and flog it and the mods. Then I'd try a different (more expensive/high end) deck...
    Which part of that have you failed to grasp?
    It may be an unconventional approach, but I understand why he's decided to carry things out that way. In fact, it's rather novel and quite sensible, given that he hasn't yet decided what his T/T is going to be. The Technics is rather unique, in terms of the requirements needed for someone unexperienced to ascertain what its potential is.
    I'm sure that otherwise David would simply have shelled out for an appropriate T/T, in keeping with the rest of his system, but then likely ended up with just A-N-other belt-drive T/T, and missed out on what quality direct-drive turntables are sonically capable of...
    Such as? It all comes down to how much David is willing to spend on a turntable. We all know that a stock SL-1200/1210 is, sonically, nothing special. It only becomes so, when judicious modifications have been carried out. Trust me, you would need only a listen to a T/T like Martin's or mine to realise this.
    If David's not willing to spend what it takes to turn his Techy into a serious high-end T/T, or even just a very good one, then by all means he should quit now and go a different route, but at the moment he's still at the most basic stage of his plan! Therefore, I think it's wise for him to continue what he set out to do.
    Indeed, if he'd listened to me in the first place, before buying the Audio Technica, he'd have been somewhat further on in his quest.....
    There are no such "fanboys" here; merely very satisfied users of what is (when suitably modified) an exceptionally good turntable. Whether David succeeds in realising that fact for himself, or not, remains to be seen.
  7. #107
    I'm Paul.
    Hi Paul,
    Marco. I have not failed to grasp anything David has explained. I'm just not convinced he may be going down the right path for him. Frankly given the revealing (and expensive) nature of the system I believe he needs to start with a higher level of front end whether it is a modified Technics or a high end belt drive. I don't think he is going to be satisfied with merely a change of cartridge. I don't presume to know his budget but he stated he has gone for the best he can afford elsewhere so why not the record deck if he is serious ?
    The 'fanboys' comment was obviously tonge in cheek but given your enthusiasm for your own superb set up I think David may have failed to consider the alternatives. I think his 'unconventional' approach may have been triggered by unfounded expectations of the standard SL1200.
    I think putting forward an alternative viewpoint may be helpfull in David coming to the right decision for him. He has a superb set up and I think he should be getting fantastic SQ with all sources especialy vinyl.
  8. #108
    I'm david.
    Martin, I'm pretty sure the vta will not go any lower. It's on the lowest setting (ie the one even below the 0 mark) and seems to be working correctly. I will double double chec today though.
    Paul, I think what you say has a lot of merit. Perhaps it is time to just review what I'm doing and how I'm going about it.
    Mark, I'm happy to throw a few quid at the Nagaoka but I just need to make sure it's the right thing. No point buying that and then two days later realising that it still doesn't hit the mark. Or buy the Jelco arm and then realise quickly that I need somethhing better.
    It might be better for me to 'go high' right from the beginning ie top end arm and cart in one go. This will be quite a gamble though as in itself that will cost and to get the best out of them I'll have to replace the other weak link ie the psu (and perhaps bearing)
    So that could be £2k in a very short space of time. Though I really want a good vinyl system I'm not sure I want to throw mega money at it as it will never replace CD for me.
    I was hoping for a happy medium ie tech + decent cart+ feet+mat+ cheaper psu = decent sounding system for a reasonable amount of money. And then perhaps continue to mod if I really had the bug but having something nice to listen to in the mean time.
    Anyway, I need to have a bit of a think
    System:
    SL1210 > Whest PS 3.0RDT> Audio Research LS17 pre> Lyngdorf RP1 room correction> Lyngdorf sda 2175 > Monitor Audio Platinum 300 speakers
  9. #109
    I'd sorta disagree that the stock deck is 'nothing special'. A good used example picked up for around the £200 mark cannot be beaten at the price. Properly set up and with a sympathetic cartridge it can hold its own against decks costing a lot more. It's metronomic timing and bass depth/slam abilities are way ahead of the field, as is build quality.
  10. #110
    Thing is, you've only scratched the surface so far, in terms of carrying out the above modifications, and yet you appear to be expecting to get most of the way there by simply changing the arm's headshell and buying a mediocre cartridge...
    It's time to up the ante, me thinks!
