Sorry to bombard this forum with my problems, but I'm loosing the will to live
After much faffing I managed to get my cart (AT 440) onto my Sumiko headshell. I tried to set it up with my Steven's protractor, bizarrely where I first set my cart was spot on. That is quite suspicious and means I probably haven't used it properly.
Anyway, that's not my primary concern for now. When I try and set the tonearm arm up to find its floating point the counterweight doesn't seem to work properly.
It seems to rotate without really engaging with the arm, it just seems to spin. I have to pull/push on it to make it move up or down the arm which of course means its not a measured/accurate increment.
I've only had the deck a few weeks and didn't notice this problem before, have I broken it?
