Well I just knew it as Mu-Metal http://en.wikipedia.org/wiki/Mu-metal but I don't know if it is also marketed under any specific brandname. I'm sure that someone here would be able to point to somewhere where you could get some - or Google may be a good starting place : http://www.google.co.uk/search?hl=en...UK%7CcountryGB
Hi Martin,
I've got to this one quite late. I just wanted to say congrats on your new turntable. It looks great and I hope you get lots of musical enjoyment from it
I've had too much booze now to write coherently but will comment more later. Happy New Year!
Happy New Year to everyone! Too much mulled wine here...
I'm Paul.
Mu metal can be hard to get hold of but for the level of interference you probably have a large sheet of brushed aluminium from Maplins or Rapid Electronics will do the job. You will need to earth though. This can be done by drilling a 3mm hole in one corner and bolting a ring crimp connector connected to an earth lead using a star washer. What ever you use it really needs to be earthed in order to work properly.
What do yoy think about the PS Audio Power Plant. Howard done a demo for me a while ago and it done many things right but I felt it made the treble a bit too smooth for my liking. However thinking of using it for everything but the power amp or pulling my trusty back up Kel84 amp and bi amping, using the Kel84 on the treble without it going through the power plant.
~Paul~
I used to run a Power Plant P300 just feeding my source components. It certainly enhanced the system with a lower noise floor, greater detail and sense of clean transparency. When I upgraded to the Premier I could at last plug the power amp in too, since it can supply a total of 1.5kW to components. This gave huge benefits, much more so than I expected from a design using a switched mode power supply. Now my system's synergy is superb with everything playing from a black noise floor, crystalline clarity and smooth extended treble.
It could be that you are hearing a small roughness in your system being removed by the Premier. It does have a smoothing effect, but listen further and you will hear more shape and texture to the notes. The PPP really is a mandatory system upgrade, in my opinion, for all systems that have reached a fundamentally good level of performance. I know of no other way of upgrading a system by so much for relatively little outlay.
I'm Paul.
Thanks Martin,
~Paul~
Dave - I want to get my cartridge alignment as precise as I can. What is the best alignment method or protractor to use with the Jelco 250?
I use the Clearaudio one; very, very expensive! There will be people here that can help though?
BTW http://www.tonepublications.com/ToneAudio/Magazine.html want to review one, and they shall!!
Dave
