I'm Jay.
Patrick i'm surprised you're not arm geometry savvy, a man of your skills. ;-)
I'm afesteringvinylphile.
Lyrics are the ramblings of man, sometimes inspired by The Creator, most often, not.
But music (melodies, harmonies, rhythms), that's God stuff.
Always was. Always will be.
One of the biggest lies ever told was that only certain kinds of people should listen to certain kinds of music.
(silent) VINYL LP SLIDESHOWS
I expect than a specific example of an arc can be a straight line
I can't state too strongly how much easier it is to setup a cartridge once overhang is correctly set. Using a jig, whether Dr F or homemade, make the overhand setting easy too. Maybe I'm just useless at setting up cartridges but it's always seemed to me that using a 2 point protractor to set overhang (north / south) and angle (east / west) at the same time is fraught with potential for error. Setting north / south first hugely speeds to process when I exercise my inadequate skills!
Even with a // arm overhang is the first thing you set.
I'm Patrick.
Oh I'm perfectly savvy - my point is that with a pivoted arm you will always have tracking error, so the only questions are where on the record it will be right, and how much out will it be elsewhere.
I'm therefore extremely skeptical that it matters that much in reality if you're a little bit out from someone's idea of 'correct'.
I'm Deleted.
You make a fair point - often one is simply moving the position of the null points - they still exist, just not exactly at the arbitrary points Baerwald etc dictate. Offset angle is another matter.
Account Deleted
Patrick, I assumed you knew. Truth is it's one of those down to personal taste things, do you prefer minimum EOS distortion and are willing to trade that off for a null further in from the start of the record and higher SOS distortion, or do you maybe prefer lower RMS distortion and align accordingly.
Fortunately because I' m generously hung it's not an issue for me.
