From reading the description Chris I believe it improves the electrical conductivity of the connection...
I don't mind at all - thanks. It's something i've just sorted this morning with the hifipig site. I've now changed the permalinks on the RCF site too -good suggestion.
I'll leave the meta as its useful to us and the wordpress link in there as i feel it deserves the mention.
The Fidelity interconnect should be a fine choice too. Same as Rega Couple (as far as I can see) and twenty quid cheaper. Great Klotz cable (IMO) and good plugs. may be better in soms ss based systems with sharp, slightly "crisp" sounding tweeters but NO loss of subtle details (unlike one or two VDH interconnects which try to do the same thing via carbon based spark-plug leads )
Hi
As I was informed that I'd been "mentioned in dispatches" I thought I'd mosey on over and see what AOS was all about! Nice forum from what I can see.
Yes, the Fidelity is the same as Rega Couple in terms of components, but with one exception: it uses Cardas quad eutectic solder which I'm a big fan of (I use this for all my soldered connections). Whilst not up there with the (only slightly more expensive) offerings from the Reference stable, it's a very good interconnect.
