This is equally interesting: “High End Cables” or Smoke and Mirrors?
Good point well made r the address -now added :-)Should add that it was there but hidden on the contact page -my error ...doh!!!! NOw made it much more prominent. Thanks guys.
With regards payment Paul chose to use Paypal as the only online method of payment for the very reason of ensuring buyers felt secure.
Apart from that, I say he's a good bloke -isn't that enough ;-)
Sorry, would somebody mind telling me what "foo" is?
Can I offer a couple of simple tips on Wordpress, hope you don't mind
In "widgets" in the backend of Wordpress drag the meta widget out of the sidebar ... It's no good to anyone visiting the site really
Also, if you go options - permalinks and select the "post name" one ... That will give him some nicer URL's
Hope that helps
Also you can probably take the Wordpress link out of the footer by editing footer.tpl
Stop nosey fuckers like me making remarks
I'm ChrisB.
Well now, if you're interested in the Laws of Physics, you should trundle over to the Accessories page of the site (lovely clean design by the way Stu - nice!). When you get there take a look at the 'Planet Protector' contact cleaner (fantastic name!).
I couldn't help noticing this bit:
"By virtue of the Quantum Tunnelling effect, this thin film between mating conductive surfaces has excellent electrical conductivity properties".
.....so I started to wonder just what the hell the Quantum Tunnelling effect is when it's at home.
I poked around the w's for a while and discovered it's tricky stuff! The Wikki usually speaks to the Thikki's amongst us like me, so after a while I went there. This is what it said:
"Quantum tunnelling refers to the quantum mechanical phenomenon where a particle tunnels through a barrier that it classically could not surmount. This plays an essential role in several physical phenomena, such as the nuclear fusion that occurs in main sequence stars like the sun,[1] and has important applications to modern devices such as the tunnel diode.[2] The effect was predicted in the early 20th century and its acceptance, as a general physical phenomenon, came mid-century.[3]
As a consequence of the wave–particle duality of matter, tunnelling is often explained using the Heisenberg uncertainty principle. Purely quantum mechanical concepts are central to the phenomenon, so quantum tunnelling is one of the defining features of quantum mechanics and the particle–wave duality of matter."
Hmmmm. OK.........still none the wiser - so then I found this video:
It seems a lot of trouble to go to just to get yer phono sockets shiny!
