I used twin 30 amp screened cable for mine if my memory serves me and a separate earth fed through steel conduit; mainly in the hope that i could sneak into next doors garden one day and conceal an earth rod and cable somewhere.
The art is to get the electrician not to take the supply from the distribution board feeding your current consumer box but to take a new mains in from the leccy boards outside supply.
MK anything should be fine with the appropriate breaker.
If you can persuade the electrician to sort out a single ground terminal buried somewhere not too dry in your garden this probably gives the best results. Not all electricians are happy doing this. You'll need to get your ground spike made up yourself if you are considering this. 1 metre x 20 mm solid copper rod should do it. Drill the appropriate sized hole in one end and side drill a row of three holes with tapped threads to grip the ground wire.
If you can get the wire welded in so much the better.
Single spur balanced Mains. Self built music server with 3 seperate linear PSU, Intel i5, 16 GB RAM no hard drive (various Linux OS). Benchmark Dac2 HGC, single ended XLR interconnects/Belkin cable. Exposure 21RC Pre, Super 18 Power (recap & modified). Modded World Audio HD83 HP amp. Hand built Monitors with external crossovers , Volt 250 bass & ABR, Scanspeak 13M8621 Mid & Scanspeak D2905/9300 Hi. HD595 & Beyer 880 (600 ohm) cans.
The whole problem with the world is that fools and fanatics are always so certain of themselves, and wiser people so full of doubts.
-Bertrand Russel
John.
