Any thoughts, Martin, that by disabling the lights on the pitch control, it may remove noise from the cricuit, in the way that disabling the strobe light does?
It's part of the clock circuit so it might have an effect. It's easy to try, with a motherboard jumper. I'll give it a go in the weekend.
as i said in a previous thread I did this for looks but when it was removed and sealed up i did notice some sound improvements, a solid sound wether this is because of removing a circuit or through filling a hole I dont know look forward to your findings Martin
why not removed ALL the bits which are not needed, just like I did ages ago? i.e. dismantle the strobe light, get rid of the pop up light and also the pitch slider??? Less stuff working from the PCB the better.
I don't use the strobe or pitch, but I do like the pop-up light (converted to LED) as it helps me cue accurately.
Hi Martin,
Have you had a chance to try this, matey? I'm curious to see if you can hear any difference
I have the PCB jumper in my pocket. Back home tonight, will try it then.
I'm a bit knackered after a huge drive down the A1(M) and M25 through the snow last night, three hours of white knuckle slipping and sliding.
Not much slipping and sliding with my Michelin Alpin (winter tyre) shod BMW; however I do have to admit that yours is a tad more powerful than mine! It's almost nice to have some adverse weather so that I can smugly drive past everyone without any drama. Those tyres were an absolute godsend last year.
Ok, this was a very simple mod to try out. Required: one standard PCB jumper as found on many motherboards and PCI cards. Remove connector CN102 and insert the jumper connecting pins 6 and 7 of the PCB socket. Easily reversible, and negates the useless pitch control and centre detent switch. You lose the LED indicator, too.
What this does is ground pins 9, 12 & 13 of IC302 (pitch control), effectively crystal locking the deck's speed.
Listening to it, I can maybe hear a further cleaning up of the soundstage making everything that little bit more vivid. It's not a night and day thing, but every little helps. A nice, cost-free mod. Thanks Phil and all the others for pointing it out.
