In the case of cryo, the process affects the audio transmission properties of the transmission line. Removal of the carbon through rapid cooling damages the molecular structure of the metal composition. PCOFC ( as used in my digital coax lead) or PCCCC are a far better and damage free solution due to the continuous and directional casting process employed to remove the carbon without destroying any inter metal bonding properties. Once you treat metal via the cryogenic process, you have to temper the metal a couple of times in order to get rid of the brittleness now introduced in the metal. Unfortunately this requires cooling and heating up the metal, thereby introducing minuscule air bubbles into the structure. Unlike carbon, which can conduct electrical audio signals, air is a non conductor within the voltage range that audio is generally operating at in your average audio device. The results of it is that cryogenically treated material is in fact less perfect as an audio medium due to its increased level of signal distortion and inaccuracies.
