Results 21 to 30 of 31
Thread: What does an inductor do in a speaker crossover?
  1. #21
    I'm inthescottishmafia.
    Switching on a push pull amp without speakers connected is fine as long as the output valves are triodes. Different matter with other valve types like pentodes. SE amps don't mind at all.
  2. #22
    See what i mean about it being a minefield?
    Best to always assume you need a full load with a valve amp It's what I'd do at any rate, then you can't go wrong
    Bests, Mark
  3. #23
    a picture helps
    Here is simplest 1st order form, the cap is stopping the tweeter getting low frequency (would be harmful at power), so it can produce nice sounds in it's comfort zone and the inductor is stopping the woofer trying to play higher frequencies at which it is crap.
    The crossing point I choose is 1000Hz (what Tannoy use on 15" HPD/Golds etc...
    As this is the most basic crossover the ramp up and down slope are shallow 6dB / octave.
    For steeper you need more components.
    Going up the scale to 4th order you get 24db/Octave and use lots of components = expensive and signal sapping.
    This might seem like a good idea as the woof does less tweeting and the tweeter less woofing - should be good, but pushing the precious signal through all these chokes and caps does sap detail / clarity and dynamics so they use as few as possible / trade off.
    I used 2nd order 12dB/octave as a compromise...
    For a 3 way you get
    You can mix driver impedance and the crossover compenent values vary to take that into consideration.
    Here the mid band is both avoiding receiving too low or too high so you have both in there - unavoidable.
    You can choose drivers that tail off naturally sometimes - the JBL2435Be's I use as upper mids go to 9000-10000Hz and then drop off naturally so no need for the components to pull them down as they are doing that anyway. Sometimes you can do the same with woofers just rising naturally - sometimes not as they comb or just sound bad.
    Here's the tool I use
    http://www.erseaudio.com/CrossoverCalculators
    There are also L-pads to reduce the volume / gain of a more efficient driver - devils work as they sap clarity / dynamics. I tried these as a stop gap but doing it at line level is much better and more controllable IMO.
    And Zobels to stop a drivers impedance raising with frequency. I use those on the bass and sub bass drivers in my system.
    You can of course use Digital Signal Processing and get 48dB / Oct slops, L-pads, time delays to align drivers and more, all done in the digital domain but it def needs an amp per driver pair and converting your analogue signal (should you have one) to digi and back again is not the best thing to do to it!
    Some use a cheapie such as the http://www.behringer.com/EN/Products/DCX2496.aspx
    play around measure and get the crossover points they like and then build a passive one - as they sound better than the 2496.
    You can get expensive ones like http://www.deqx.com/ for several thousands. £6.5K to do my 5 way horn system - gulp! Some can do room correction too...
    I tried Anti-mode 8033 on Reid's recommend and like it but that is only messing with 10-150Hz and it does not muck it up with DAC and ADC at those frequencies and there's little else to can do.
    Fun and Games.
  4. #24
    Quote Originally Posted by Reid Malenfant View Post
    Aye I suppose so, unless you know yer valves.
  5. #25
    I'm Neal.
    Depends on the PP amp Ali, not all will complain...
  6. #26
    Welcome back, Neal - long time no see!
  7. #27
    Man oh man look what I started...
    Jeff :UBERTHREADKILLER
  8. #28
    come on - you asked for it
    Quote Originally Posted by goraman View Post
  9. #29
    Hi Steve,
    Your excellent pics have disappeared, mate (now getting a "Temporarily Unavailable" message) - makes the thread look rather untidy...
    Can you fix it?
  10. #30
    I'm Neal.
    Thanks Marco!
