Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: What does an inductor do in a speaker crossover?
    Default What does an inductor do in a speaker crossover?
    I always see 2 spools of wire inductors in every cross over what do they do,I also noticed they are almost always next to a resistor.
    Jeff :UBERTHREADKILLER
    I'm AMusicFanNotAnAudiophile.
    Low pass filter.
    Sometimes they have a resistor in circuit to stabilise the speaker drive unit impedence.
    Chris
    Once we've made sense of our world, we wanna go fuck up everybody else's because his or her truth doesn't match mine. But this is the problem. Truth is individual calculation. Which means because we all have different perspectives, there isn't one singular truth, is there?
    Low pass filter.
    I'm still not getting it,you mean it filters out low frequencies?
    In the case of an inductor feeding a bass/mid it rolls off the treble. An inductor has a property known as inductive reactance & effectively what this means is that the resistance of the coil of wire increases the higher the frequency goes - so it rolls off the treble because it's in series with the bass/mid!
    In the case of a tweeter it will be in parallel with the tweeter & as it's resistance increases with frequency it will tend to shunt less power to ground the higher the frequency goes In co-operation with a capacitor this will increase the power to the tweeter as the frequency increases.
    Resistors are generally on the tweeter side as these tend to be a bit more efficient than bass/mids
    Bests, Mark
    Passes them on.
    Chris
    Ok,so inductance creates the roll off,I always thought caps did that.
    Caps are hi-pass.
    Chris
    Capacitors do the opposite Well no, they do create a rolloff but in the opposite sense
    Capacitive reactance as it's known creates a reducing impedance (resistance) with increasing frequency.
    So imagine your bass/mid again, it has a choke (inductor) feeding it in series & a capacitor shunting the driver. As frequency increases the choke will increase in its AC resistance & the capacitor will decrease in it's AC resistance - it creates a steeper rolloff
    In the case of a tweeter being fed in series from a capacitor & having an inductor shunting it you get this... As the frequency decreases the capacitor displays more AC resistance thus rolling off the power to the driver & the inductor also has less AC resistance also creating a steeper rolloff..
    Bests, Mark
    It seems a miracle speaker crossovers work at all.
    What alot going on for so few parts.
    Quote Originally Posted by goraman View Post
    Jeff it gets worse as no drive unit has a fixed impedance, they all vary all over the place as well which can bugger up the crossover frequency & driver phase. As you can imagine this make things more complicated
    & just to make things even worse the driver sensitivity varies over frequency as well
    So yeah, it's a minefield out there
    This is why I like electronic crossovers as they are accurate. A whole lot of problems get left behind
    Bests, Mark
